    Cool brake booster 99 6.5
    have 99 chevy 6.5 3500hd.I changed brake master cyl.1 week later booster started leaking.found used one for 60.00.that came off 98 model.tried bleeding lines and still have very little brake pedal.don,t know what else to do right now ,need suggestions?
    try doin a gravity bleed on all your wheels at once for about 30 mins if its just you working on it might have some air trapped in system also check to see all the fittings are tight and not pullin air into the system
    Thumbs up
    thanks for the reply grimreapersshadow,I found out that the push rod was shorter than one came out no getting long enough travel for piston.swtiched push rods and works now I have brakes.
  1. Brake Booster Leak
    By r768 in forum Lifted & Offroad Suspension
    Last Post: 06-27-2010, 08:57 AM
  2. No Brake Booster Vacuume
    By Demick in forum GM Powertrain
    Last Post: 12-02-2009, 07:41 PM
  3. Help Please! How to remove brake arm from booster???
    By daveingland in forum Lifted & Offroad Suspension
    Last Post: 08-27-2009, 09:22 PM
  4. Little help? power brake booster
    By jam3466 in forum Lifted & Offroad Suspension
    Last Post: 06-22-2009, 09:17 PM
  5. service brake booster
    By rrthomas in forum General Chevy & GM Tech Questions
    Last Post: 05-15-2009, 11:23 AM
