I need to raise the front end of my 89 chevy 2500 2wd about 3"
does anyone know the best and cheapest way to do this? i.e. springs, spacers...
thanks
you can get a leveling kit for probably under $200, probably the best way to do it and cheap
David
2004 Silverado 2500 Crew Cab 4x4, Airraid cold air intake, Throttle body spacer, Magnaflow exhaust (true dual to 2 in 1 out muffler), 6" ProComp lift (add a leaf and 5" superlift rear block), Bilstein shocks, 35's (Cooper Disoverer ST's) and 4.10 gears, Rhino Liner, fiberglass tonneau cover, extended stainless steel brake lines, firestone airbags.
1960 Land Rover Series II 88
2002 Nissan Altima (wife's Car)
1999 Saturn SC1 (the new commuter car)
Leveling kits on Ebay are under $100.00, both types available. Put one on my sons 2008 GMC with no problems. No difference I can see from the brand name kits.
I'm also interested on putting a leveling kit on my '97 c1500. I have been looking at the coil spring spacers, wich are under $40. Can someone give me a link, or product name of a good leveling ket?
Would something like this work for me?......http://cgi.ebay.com/ebaymotors/88-98...Q5fAccessories
http://www.suspensionconnection.com/ check here. someone else posted this link on here before and i saved it because i'm looking for the 2" suspension lift kit
2008 Chevrolet Silverado 1500 LTZ 5.3L EC/Std Bed 4x4 Flexfuel
Full Metal Jacket Spray on Bed Liner
Black Powder coat Diamond Plate Weatherguard Tool Box
Corsa Performance Sport Exhaust System
K&N Flat Panel OEM replacement Air Filter
Bridgestone Dueler A/T Revo tires P275/55/R20
Black Reflective pinstripe and VORTEC hood lettering
Billet front bowtie
Rear Bowtie Delete
Blue strobe grille lights
Blue strobe rear window lights
Blue LED Mini Light bar in front Grille
auto parts stores sale leveling kits but only some of them just call up your local auto parts store or type in the autoparts store name in the computer and search there online store and there pretty cheap
I dont know of anybody that makes a leveling kit for your year and model (2500) truck. Becareful about putting larger springs up front because you wont be able to aline it. If you look at some of the kits for newer body styles (90-99) they have longer upper control arms to stand the tire and wheel back up as when you put a larger spring on it tilts the wheel and tire beyond the alinment specs. Because your truck is about twenty years old if it has the original front springs Im sure they sagging and worn out. Maybe you could replace them with a pair of Moog or equal heavy duty front springs and this should lift the front some (depending on how worn the springs are).
i ran a spring spacer in mine, the only thing is they a bitch to put in and i just had a shop do it for me, and after that you gotta get an alignment done cuz it s gonna wear downyour tires fastercuz it brings the bottom in more, so if you know any shops you know well and can get a deal thats the best, but its really hard to to on my c1500 95
what does a levelin kit do ?
Bookmarks
