Results 1 to 3 of 3
    Legend dsfloyd has a brilliant future
    May 2009
    San Diego CA
    3 Post(s)
    Question Front drive shaft
    2004 K2500
    Here is my problem. I spung a leak in my front pinion seal. It is set to get fixed on Friday along with some other stuff under warranty. The problem is that it went from a leak to massively leaking (today)while driven. The reason it wasn't going in sooner is because I need my truck the next three days. My question is if I remove the front drive shaft will it keep that front pinion from spinning and leaking oil everywhere or will that pinion still spin (I don't remember if the shaft spins in 2 wheel drive because of the Tcase or the wheels). Also since it is a slip shaft at the transfer case will there be an issue driving it with the hole left at the transfer case. Or is my best bet to rent a vehicle and take it to the shop that is doing the work now?
    David
    2004 Silverado 2500 Crew Cab 4x4, Airraid cold air intake, Throttle body spacer, Magnaflow exhaust (true dual to 2 in 1 out muffler), 6" ProComp lift (add a leaf and 5" superlift rear block), Bilstein shocks, 35's (Cooper Disoverer ST's) and 4.10 gears, Rhino Liner, fiberglass tonneau cover, extended stainless steel brake lines, firestone airbags.
    1960 Land Rover Series II 88
    2002 Nissan Altima (wife's Car)
    1999 Saturn SC1 (the new commuter car)
    May 2009
    San Diego CA
    3 Post(s)
    nevermind. with timing and need i decided just to rent a vehicle and get the truck in today
    David
    Jr. Apprentice spottweld is a glorious beacon of light
    Jul 2009
    Peach Bottom PA
    as long as your hubs are unlocking properly and your t-case is in neutral your pinion shuldn't be spinning if it is you have an underling problem
Similar Threads
  1. 87 suburban front drive shaft
    By socal77k5 in forum General Chevy Tech Q&A
    Last Post: 07-05-2010, 12:17 PM
  2. Front Drive Shaft
    By Minnesota Mudder in forum Powertrain
    Last Post: 02-15-2010, 12:31 AM
  3. WTB 241c Transfer Case & Front Drive Shaft
    By homer911 in forum For Sale & Wanted to Buy
    Last Post: 02-16-2009, 11:25 PM
  4. FS:: Superlift front drive shaft
    By 95burban in forum For Sale & Wanted to Buy
    Last Post: 12-29-2008, 10:00 PM
  5. WTB Front drive shaft
    Last Post: 11-10-2007, 08:43 AM
