Results 1 to 8 of 8
    Sr. Apprentice rdnkdrummer is a glorious beacon of light
    Jul 2009
    Weatherford, TX
    Default '89 Suburban doesn't like humidity
    This will be my "work in progress" page for my '89 Suburban. It's been very "weird" lately. won't start on humid days. Before this started happening, I remember on a few humid days that it would "hesitate" while driving when cold, once warmed up it was fine.
    I had an '01 4.3V6 pickup before, and there was a problem with condensation in the distributor cab which caused a similar problem. I know I need to get new cap, rotor, plugs, and wires on this truck, just because it's "time".
    I'm starting this thread to see if any of you have had an issue like this, and it WASN'T the cap/rotor causing the problem. Over the next month I will be replacing: cap, rotor, plugs (what kind should I get? +4 or Delco platinum?), and wires. Also I will be doing a good sea-foam cleaning, in oil, gas, and brake booster line. I'll update you as things progress.
    If you have any ideas on probable causes of my anti-humidity suburban, please post.
    Muchas Gracias!
    '95 1/2 ton Suburban 4wd 350, 140K, w/ tornado and k&n filter | everything else stock
    '89 1/2 ton Suburban 2wd 350, 200+K, completely stock except 31 x10.50 tires & 40 series flowmaster
    '85 1/2 ton Suburban 2wd 350, 250+K, burnt valve , edelbrock 50 carb, comp cam, silvolite pistons, HiPerf distributor, 18" glasspacks
    Legend 2COR517 has a reputation beyond repute
    May 2009
    Maine
    Do the SeaFoam before you put your plugs in. As for plugs, and cap&rotor, Only use AC Delco. My truck did not run well with the +4. Napa Premium wires are fine. Don't forget air and fuel filter, and PCV Valve. An O2 sensor is a good idea too. And, on the 89, you need to check/set the timing.
    Jul 2009
    Weatherford, TX
    Thanks for that...i will seafoam before plugs, made that mistake once before! That's what happens when you mix Coors Light with a tuneup. Air filter and pcv are new already. question about fuel filter, as I'm new to TBI, I've only messed with carbs...where is it, and how hard is it to change?
    May 2009
    Maine
    Fuel filter should be on the inside of the left frame rail. Usually under the drivers door area. Might want to spray some penetrant on the fittings for a few days. Sytem is under pressure, but once you crack a fitting open it will bleed right off.
  5. #5
    Sr. Mechanic bill190 is a glorious beacon of light
    Jul 2009
    Oregon
    Check the spark plug wires for cracks in the insulation.
    Also test your Coolant Temperature Sensor which provides engine coolant temperature data to the engine computer.
    92 GMC Sierra 2500
  6. #6
    Jul 2009
    Weatherford, TX
    Thanks for the fuel filter info...are there two different coolant temp sensors: one for gauge and one for computer?
  7. #7
    Jul 2009
    Oregon
    Quote Originally Posted by rdnkdrummer View Post
    There could be. Older vehicles have two.
    The one for the computer is called the Engine Coolant Temperature Sensor, would have two wires, and would be located near the top radiator connection on the engine.
    If you have a Coolant Temperature SENDER (separate for gauge), this would have one wire and would be located on the side of the engine near cylinder #1.
    With the newer vehicles, they use one sensor and get a computer to calculate the appropriate readings for the instrument cluster gauge.
    92 GMC Sierra 2500
  8. #8
    Jul 2009
    Weatherford, TX
    WAY late back to this post...as the truck is now totalled....that's beside the point. New Distributor fixed the problem. Plugs, wires & sea foam helped mileage. Got up to 16-ish. At some point before I owned the truck...there must have been a loose distributer cap that collected some condensation that caused permanent damage that worsened over time. Good to know for future.
Similar Threads
  1. Replies: 0
    Last Post: 11-16-2009, 12:40 PM
  2. Replies: 0
    Last Post: 08-05-2009, 03:40 PM
  3. Chevrolet : Suburban 2000 Chevy Suburban MONSTER TRUCK FULL CUSTOM
    By Steve in forum Chevy Trucks For Sale eBay
    Last Post: 07-28-2009, 02:00 PM
  4. Replies: 0
    Last Post: 07-14-2009, 11:10 PM
  5. Replies: 0
    Last Post: 07-06-2009, 09:30 PM
