Page 1 of 2 12 LastLast
Results 1 to 10 of 20
    Sr. Apprentice noahraysanders is a glorious beacon of light
    Jun 2009
    Exclamation rpm s surging
    my rpms surege between 40-50 mph please help
    Legend 2COR517 has a reputation beyond repute
    May 2009
    Maine
    What year/model/engine/transmission? Do you have a tach, and the guage is moving, or can you hear the engine surge, or both? And how much variance in RPM do you have?
    Sr. Apprentice jdickerson83 is a glorious beacon of light
    Aug 2009
    Indiana
    2COR517,
    I had a similar problem w/ my 96 Blazer. All I did was add more transmission fluid and it's worked fine ever since. Check the tranny fluid and if it's low, that's your problem.
    Good luck.
    Aug 2009
    Indiana
    Glad you got everything taken care of
    Joe
    1994 Chevy Silverado 5.7L 350 V8
    Extended Cab
    FlowMaster Super 44 Series Muffler
  5. #5
    Jun 2009
    Quote Originally Posted by 2COR517 View Post
    2002 chevy silverado 5.3
    i can see the tach move and here the engine surge
  6. #6
    May 2009
    Maine
    I presume you checked the ATF. Can you give a little more info? What driving conditions, hills, flat, etc. Throttle position. If you speed up to say 70, does it stop?
  7. #7
    Legend Jimmiee has a reputation beyond repute
    Feb 2009
    Reno, Nevada
    Quote Originally Posted by noahraysanders View Post
    Another thing to check is to see if it will do it in 3rd, then second. If it does it's not a transmission problem.
    Jim
    2004 SILVERADO 2500HD LS
    Pro Comp Leveling Kit
    Pro Comp Programmer
    Bilstein Shocks
    Linux Bed Liner
    Tinted Windows
    Other rides:
    1967 Landcruiser <350 Chevy>
    1970 Camaro
    1990 Geo Metro Convertible
    2007 FJ Cruiser
  8. #8
    Jun 2009
    it does it between 40 -50 mph on any incline
  9. #9
    Feb 2009
    Reno, Nevada
    It could be the torque converter locking and unlocking. A bad brake switch can do this. To determine if it's the converter or not drive it at 45 MPH and when it starts surging press the brake pedal down about 1 or 2 inches. Just enough to turn on the brake light but not hard enough to apply the brakes. This will unlock the converter. IF it quits surging then you have found the problem. If it doesn't quit you can at least rule out the torque converter.
    Jim
    Pro Comp Programmer
    Bilstein Shocks
    Linux Bed Liner
    Tinted Windows
    Other rides:
    1970 Camaro
    2007 FJ Cruiser
  10. #10
    Jun 2009
    [QUOTE=Jimmiee;162888]It could be the torque converter locking and unlocking. A bad brake switch can do this. To determine if it's the converter or not drive it at 45 MPH and when it starts surging press the brake pedal down about 1 or 2 inches. Just enough to turn on the brake light but not hard enough to apply the brakes. This will unlock the converter. IF it quits surging then you have found the problem. If it doesn't quit you can at least rule out the torque converter.[/QUOT
    i have to keep my foot on the gas too right
Similar Threads
  1. surging 1994 Chevy Suburban
    By mudpuppy in forum Chevy Suburban Forum (GMC Yukon XL)
    Last Post: 02-04-2012, 01:07 PM
  2. air conditioning surging?
    By Clean-Dezert.org in forum Chevy Silverado Forum (GMC Sierra)
    Last Post: 09-16-2009, 05:27 PM
  3. Occassional surging
    By BlackHawk99 in forum Powertrain
    Last Post: 07-06-2009, 07:48 AM
  4. surging issue
    By zombieclod in forum Chevy Silverado Forum (GMC Sierra)
    Last Post: 04-10-2009, 03:53 PM
