Was wondering if i do a lift on my truck would i have to mod the trasmission or even possibly the drive shift? and doing the lift do i run the possibility of killing my trasmission?
Thanks for the help
shouldnt be any mods needed that i know of unless you go higher than 6in, as for killing the tranny may have a little more strain on it from larger tires but nothing to worry about
2003 Z71 Silverado LS
Access roll up cover
Bed Rails
Billet Grill insert
Bed Rug
CB with PA system
Waiting to be installed
The only thing to watch is the drive line angle. Most lift kits adjust for this. Too steep of an angle and you start breaking extension housings and transfer cases. Even if the angle is within limits you will wear out u joints faster as the angle increases. If I were going to do a 6" lift and use the truck off road I would have a custom shaft made that uses a double cardan joint. This setup gives you a lot more angle and cuts u joint wear in half.
Jim
2004 SILVERADO 2500HD LS
Pro Comp Leveling Kit
Pro Comp Programmer
Bilstein Shocks
Linux Bed Liner
Tinted Windows
Other rides:
1967 Landcruiser <350 Chevy>
1970 Camaro
1990 Geo Metro Convertible
2007 FJ Cruiser
good to know... i was planning at the most a six inch lift... and not much off roading just for the looks
thanks
Bookmarks
