    Default Rear wheel skid. [Expired Topic]
    The rear wheels on my 98 Burb locked up in a car park after going over a speed hump.(at 2mph). Now it will only drive in 4wd and makes transfer noise every revolution. In 2wd transmission turns and car just rocks forward with every revolution. With brake applied transmission just clunks. Any ideas welcome.
    Default RE: Rear wheel skid.
    ??? Locked up as in they won't turn at all? How does it drive in 4wd? Never heard of this happening before without the tranny locking up.
    Steve
    10 Chevy Traverse LT AWD
    Legend unplugged's Avatar
    Sep 2006
    High Deserts of SoCal
    Default Broken axle maybe?
    Sounds like a broken axle to me. 2wd no forward motion. 4wd it moves. GM uses "open differentials" that provide equal torque to each wheel. (on the same diff) That means that if zero torque is applied to the left wheel, then zero torque is applied to the right wheel. If you have a broken axle, you get zero traction at the other wheel. See more at How Stuff Works
    Jack up the rear of the burb so that both rear wheels are off the ground. Spinning one wheel should turn the other wheel. If it doesn't, its likely a broken axle. If you don't have a floor jack to lift the rear at the differential, take it to your mechanic and put it up on a lift.
    Open diffs are not the best for serious off road stuff. I would rather go with a locker differential. The air actuated lockers are my choice.
    High Desert SoCal
    02 Honda Civic LX
    Aug 2006
    florida
    it could be broken pinion gear had one break on camero once car wouldnt roll fwd but did roll backwards johnny
  1. Rear disk breaks [Expired Topic]
    By Davandy in forum Chevy Suburban Forum (GMC Yukon XL)
    Last: 06-14-2006, 10:17 PM
  2. Rear hatch release. [Expired Topic]
    By Truckernate in forum Chevy Suburban Forum (GMC Yukon XL)
    Last: 06-03-2006, 03:29 PM
  3. whats the best wheel size to upgrade to on a suburban [Expired Topic]
    By 97bigredburban in forum Chevy Suburban Forum (GMC Yukon XL)
    Last: 05-11-2006, 10:07 PM
  4. Rear A/C Leaking Oil [Expired Topic]
    By Silverbullet555 in forum Chevy Suburban Forum (GMC Yukon XL)
    Last: 04-23-2006, 02:03 AM
  5. the rear deflector thats on top rear above 3rd brake lights [Expired Topic]
    Last: 09-13-2005, 12:34 PM
