I have an '88 silverado that the pass window will not go down with either button pushed. I have put on a new motor and tried a new switch on both sides. When i pull the regulator and re-install with the window down a little the pass button will raise the window but not the driver side. I'm stumped. Could it be the regulator itself, I only changed the motor. It did work a couple of times after the motor change and then nothing.
Thanks for any info you guys can give.
DGUT - Wichita KS
1988 Silverado 5.7
(Former Vehicles)
2001 Silverado 1500 LS
1993 Silverado Indy Pace truck
Jim
2004 SILVERADO 2500HD LS
Pro Comp Leveling Kit
Pro Comp Programmer
Bilstein Shocks
Linux Bed Liner
Tinted Windows
Other rides:
1967 Landcruiser <350 Chevy>
1970 Camaro
1990 Geo Metro Convertible
2007 FJ Cruiser
Do voltage drop testing of the wiring with a multimeter...
http://www.engine-light-help.com/voltage-drop.html
How to use a multimeter...
http://www.google.com/search?hl=en&s...imeter&aqi=g10
Then take a coat hanger and bend it back and forth in the same place. Notice how it eventually breaks in that spot.
Then imagine the wires going from your doors to the vehicle at the hinge. Imagine opening and closing your car doors 1000 times and what could happen to those wires!
92 GMC Sierra 2500
Bookmarks
