Results 1 to 7 of 7
    Jr. Mechanic jbeall is a glorious beacon of light
    Feb 2009
    Default Question about towing and wagons vs trailers
    Hi All,
    I've been looking into towing some, and I had a question--why is that I never see a "wagon" type of trailer, made for on-road vehicles?
    One of the common issues when dealing with trailering is making sure you don't exceed your tongue weight or the axle weight on your towing vehicle. But that's only because all (?) trailers made to be towed behind on-road vehicles do not have a pair of wheels in the front.
    In agriculture, they've had wagons that effectively make those two things non-issues. You have (at least) a pair of wheels in the front, and in the bag, and the front pair of wheels are articulated so that they can turn when the tow bar attached to the vehicle is turning.
    He's an example (hopefully these images will work!):
    I'm sure you've all seen wagons like this. They make them big (for ag use) and small (for home use, and as toys). You can see just by looking at them that there is no downward load transmitted by the tongue--the entire downforce of the wagon's load is transmitted to the wagon's own tires. Thus, the only thing the hauling vehicle needs to worry about is, well, hauling it (forward).
    But in the on-road trailering world, it seems we never see these kinds of vehicles. The trailers I come across always have wheels either center or to the rear of the vehicle, and a significant downforce is transmitted onto the towing vehicle's hitch. In the case of heavier loads, a weight distrbuting hitch is necessary in order to prevent the towing vehicle from being dangerously unbalanced, with too much downforce on the rear axle, with then pushes the front (steering) wheels off the ground.
    So, I've been wondering--why build trailers in this fashion, so that downforce is even transmitted to the towing vehicle at all? I'm guessing there's some reason that the "wagon" type of trailer is not desirable in on-road conditions (hence we see wagons primarily in ag use)--but I can't figure out what that reason is?
    Would someone mind enlightening me?
    -Josh
    Legend phoebeisis has a brilliant future
    Jun 2006
    River Ridge Louisiana-4 miles W of New Orleans-didn't flood-water stopped 800 yards away.
    Hmmm, that is a good question.I don't have a good answer, but I have some guesses.
    Maybe it makes sense to add weight to the drive wheels so they won't slip going uphill on snow/ice/mud etc with the extra load.
    Charlie
    1998 suburban-
    1/2 ton
    199500 miles
    River
    Ridge,LA
    Legend Jimmiee has a reputation beyond repute
    Feb 2009
    Reno, Nevada
    Quote Originally Posted by phoebeisis View Post
    Charlie
    Good answer Charlie. The tractor needs all the weight it can get on the drive axles. If there were a wagon trailer attached the tractor would spin the wheels in poor traction conditions like rain, ice and snow. Chains would not help as the trailer is just too heavy with a wagon axle in front.
    Jim
    2004 SILVERADO 2500HD LS
    Pro Comp Leveling Kit
    Pro Comp Programmer
    Bilstein Shocks
    Linux Bed Liner
    Tinted Windows
    Other rides:
    1967 Landcruiser <350 Chevy>
    1970 Camaro
    1990 Geo Metro Convertible
    2007 FJ Cruiser
    Legend tbplus10 has a reputation beyond repute
    Mar 2007
    -97.0482020 N, 32.6625890 W
    1 Post(s)
    1 Thread(s)
    Semi's sometimes haul a second wagon style trailer.
    Weight over the rear wheels is one issue also wagon style trailers arent as stable in sharp turns.
    Tim
    2011 Silverado 1500 LT
    2008 HHR LT
    1999 Tacoma SR5 TRD 4X4
    1993 Jeep Wrangler
    1991 Toyota Rock Crawler
    2009 Harley Davidson Nightrain
    2004 Harley Davidson FLHT "Bagger"
    2003 Glastron GXL Bowrider
  5. #5
    Sr. Mechanic bill190 is a glorious beacon of light
    Jul 2009
    Oregon
    Actually they are a NIGHTMARE to backup! (With a tractor you can look down and see what is going on with the hitch, a car you can't)
    Something similar is a car "tow dolly" like in the picture below.
    Here is says "Do not attempt to back up your rental truck with the tow dolly attached"...
    http://www.pensketruckrental.com/per...tow_dolly.html
    Car tow dolly...
    92 GMC Sierra 2500
  6. #6
    Jr. Engineer ahm1127 is a glorious beacon of light
    Jan 2009
    Pennsylvania, United States
    There is no backing up with a wagon style trailer, 1 to many turning points. You will only see a tractor with 2 trailers on the highway, remove 1 when going to local streets. It would be nice to tow a truck with a wagon trailer instead of a regular trailer.
    Aaron M. of PA
    05 Suburban, Suzuki Aerio
    90 Suburban, 00 Tahoe
  7. #7
    Jr. Mechanic wayned is a glorious beacon of light
    Dec 2007
    ne fl
    you need 60% wight on tongue at high speed to reduce sway
Similar Threads
  1. towing question
    By Mike S. in forum Chevy Tahoe Forum (GMC Yukon, Cadillac Escalade)
    Last Post: 05-14-2010, 10:37 AM
  2. Towing question?
    By fd8215 in forum Powertrain
    Last Post: 05-08-2010, 09:19 PM
  3. trailers, lights, wiring question
    By starsilverado in forum General Chevy Tech Q&A
    Last Post: 01-04-2010, 07:05 AM
  4. Towing question
    By R&S Spl. in forum General Chevy Tech Q&A
    Last Post: 04-09-2009, 09:54 AM
  5. 4.8 towing question
    By mapper in forum Chevy Silverado Forum (GMC Sierra)
    Last Post: 03-30-2009, 12:34 AM
