Results 1 to 10 of 10
    Newbie Custmx1 is a glorious beacon of light
    Aug 2009
    ATL
    Default 97 GMC Truck Shutting Off Randomly
    Well, I've got a 97 GMC Truck and I love it. It hasn't given me any real problems until recently.
    About a month ago when I would shut it off there would be something still running, it sounded like a faint buzzing that would come from between the cab and the bed of my truck. Don't ask how but I figured out that if I turned the ignition to almost start the engine it would usually shut the buzzing off after 5-10 seconds. Not sure if it's relevant or not.
    But now over the past week my truck has shut off two times while I was driving it, the radio was still on but all the gages dropped to zero and had no power. Not sure what is going on wanted to know what I might be getting myself into as far as repair. Thanks!!
    Master Mechanic tattooed4life is a splendid one to behold
    Apr 2008
    Stevensville MI
    The buzzing sounds like the fuel pump is still running to me. As for the truck randomly shutting off, is or has your security light been coming on?
    1997 Chevy K3500
    4x4 X-Cab Dually
    454 Dual Exhaust
    Aug 2009
    ATL
    I haven't noticed it. However when the truck shuts off a majority of the dash lights come on, air bag, check gage and battery... The two times it has shut off it has been early in the drive, like within the first 1/4 mile. I'm totally at a loss....
    Legend 2COR517 has a reputation beyond repute
    May 2009
    Maine
    Sounds like an ignition switch or relay to me.
  5. #5
    Legend vncj96 is a name known to all
    Feb 2008
    Red Wing, Minnesota, United States
    1 Post(s)
    i say fuel pump
    5.7 K&N & True Dual Exhaust
    Hypertech III
    05 17" Silverado rims
    99 LS 1500 5.3 "THE MULE"
    Reg Cab Long Box
    285/75/16E Dunlop Rover M/T
    ___________________________
    Jason
  6. #6
    Sr. Mechanic bill190 is a glorious beacon of light
    Jul 2009
    Oregon
    Problems like this are a pain to troubleshoot because they are intermittent.
    You can't go tracking down the problem because it goes away!
    But there is a method/system to finding the problem. Just might take awhile, but you will eventually find it.
    That is to set various test devices up so you can "see" what is going on with various systems.
    Now one of the things this could be is the "cam sensor" or its associated wiring. Or a ground or +12 volts provided to that sensor. As the distributor cam rotates, this gizmo sends out pulses of electricity. This tells the engine computer the engine is running. And it is the basis of sparking. Without this, no spark!
    And this signal would normally be checked with an oscilloscope. Perhaps you could run some wires to the engine compartment (through an open window from the cab) and monitor this signal with a voltmeter set on AC volts?
    Anyway you would need a GM Factory Service Manual set so you could look at the wiring diagrams and see where to tap in your wires to monitor this. Order this from helminc.com or a GM dealer.
    Then get someone to drive around with you and keep a constant watch on the multimeter as you drive. See if this signal stops just as the engine dies.
    Fuel pressure: Or you could hook up a T to the fuel line and run a fuel pressure gauge through an open window. Keep an eye on that while driving. See if you lose fuel pressure just before it dies.
    Or electrical problems: Connect test wires to key points. See if you are losing electrical power to the electronic spark module. See if you are losing electrical power to the engine computer.
    For "nasty" intermittent electrical problems where the power may blip off for just a moment, you can get a "recording multimeter" which records the voltage. You can play this back and see if there was a momentary loss of power.
    Also just to check if you are losing spark in general, I suppose you could get one of those inductive timing lights and put the inductive pickup on a spark plug wire near the passenger firewall. Then if wires long enough, run it through the window. Then drive around with your passenger constantly watching the flashing light to see if it stops flashing before the engine dies. (And that you have lost spark).
    Alligator clip test leads like these can be helpful for setting up test wires...
    92 GMC Sierra 2500
  7. #7
    Jr. Mechanic jt_5.7 is a glorious beacon of light
    Apr 2009
    its the ignition switch i had to replace one in my teachers truck
  8. #8
    May 2009
    Maine
    Quote Originally Posted by vncj96 View Post
    i say fuel pump
    Why would a fuel pump cause the dash to shut down/warning lights to come on?
  9. #9
    Jr. Engineer
    97chevz71 is a glorious beacon of light
    May 2009
    Perry County, Pennsylavania
    The buzings is defintily the fuel pump.
  10. #10
    May 2009
    Maine
    I agree the buzzing is likely the fuel pump, though I was reading somewhere recently a guy was having his ABS pump come on after shutting down.
Similar Threads
  1. 2003 Sierra AC shutting off?
    By BigR in forum Audio / Video Electrical
    Last Post: 05-04-2010, 09:33 PM
  2. 99 Tahoe randomly cutting off
    By wedgers in forum Powertrain
    Last Post: 01-10-2010, 11:16 AM
  3. Overhead Map Light Shutting Off Gauge Lights!!!!
    By paguerra in forum Audio / Video Electrical
    Last Post: 05-06-2009, 06:35 PM
  4. 99 shutting off while driving, keeps blowing fuses after rebuilt trannie
    By daronminor in forum General Chevy Tech Q&A
    Last Post: 03-25-2009, 10:58 PM
  5. Shutting down cylinders for better mileage?
    By tbjosh in forum Chevy Trailblazer Forum (GMC Envoy)
    Last Post: 11-15-2005, 07:01 PM
