Results 1 to 5 of 5
    Jr. Apprentice Six point is a glorious beacon of light
    Feb 2009
    Alberta
    Question Mystery Code
    The Check engine light came on the other day ,plugged in the OBD reader ,cross referenced to the handy Engine code list sticky at the top of this forum ,read # P0332 -knock sensor 2 circuit low input,bank 2.I've got three questions.
    What is it?
    What does it do?
    How do I fix it?
    Info greatly appreciated.
    Jr. Engineer
    masterfoxscout is a glorious beacon of light
    Apr 2009
    Fairbanks, AK
    What year truck is it?
    That is the same code I just dealt with. It is a bad catalytic converter. The good thing is, newer cats are covered nationally by the government for 8 years, well in the US that is. It took my dealer a week to get the new cat in and about 4 hours to put it on. Hope this helps.
    Also, don't clear the code as the dealership has to have the code reporting from the PCM/ECM.
    2005 Chevy Silverado Z71 in Black
    6" BDS Suspension Lift | 3" BDS Body Lift |17" Rock Crawler Stellies | 35" Cooper STTs | 4.56 Yukon Gears | AirAid CAI and TBS | Flowmaster 40s | HyperPAC Programmer
    2001 TJ Sahara in Sienna
    3.5" RE Suspension Lift | 33x12.50 Baja MTZs | D30/44 | ROKMEN Merc Front Bumper | Warn Rockcrawler Rear w/ Carrier | Warn M8000 Winch
    Legend Jimmiee has a reputation beyond repute
    Feb 2009
    Reno, Nevada
    Quote Originally Posted by Six point View Post
    What is it?
    What does it do?
    How do I fix it?
    The knock sensor contains a piezoelectric crystal which can hear a knock from your engine.
    The knock sensor listens for detonation but it hears all unusual knocking noises.
    When the knock sensor hears a knock it tells the PCM. The PCM trys to stop the knock by retarding your timing. It can inhibit 4th gear and lock-up if necessary. The PCM then sets a Code.
    To fix it you have to determine whats knocking. A lean condition can cause a real knock condition as can timing. A belt tensioner, lifter, exhaust leak, boom box stereo can cause false knock conditions.
    Jim
    2004 SILVERADO 2500HD LS
    Pro Comp Leveling Kit
    Pro Comp Programmer
    Bilstein Shocks
    Linux Bed Liner
    Tinted Windows
    Other rides:
    1967 Landcruiser <350 Chevy>
    1970 Camaro
    1990 Geo Metro Convertible
    2007 FJ Cruiser
    Feb 2009
    Alberta
    Default Mystery Knock
    Thanks for the info guys.I was hoping the problem might be with the sensors , the code # suggests low input to bank 2.I priced out the sensors at $75 ea.,the wiring harness at $50 and the intake gasket set at over $200!Not sure about the cat converter but I'll definately check for noises before I spend the coin and time to pull the intake.
  5. #5
    Feb 2009
    Reno, Nevada
    If you had a scanner you could bring up the knock sensor PID and watch the feedback. The data should change instantly as you tap on the manifold with a 3/4" wrench or the like. So you would be able to tell if the sensor is working. If both sensors are working there would be no reason to change them.
    Jim
    Pro Comp Programmer
    Bilstein Shocks
    Linux Bed Liner
    Tinted Windows
    Other rides:
    1970 Camaro
    2007 FJ Cruiser
Similar Threads
  1. Mystery Clunking
    By sierrasst in forum Lifted & Offroad Suspension
    Last Post: 10-18-2010, 05:35 PM
  2. Overheating Mystery
    By MonroeBobo in forum Chevy Tahoe Forum (GMC Yukon, Cadillac Escalade)
    Last Post: 07-19-2010, 06:36 AM
  3. Mystery Part #
    By mrcaddy in forum Chevy Suburban Forum (GMC Yukon XL)
    Last Post: 06-29-2009, 08:20 AM
  4. Mystery Pipe
    By tfusc1 in forum Powertrain
    Last Post: 09-01-2008, 10:31 AM
  5. Mystery Engine Light
    By cchas14 in forum General Chevy Tech Q&A
    Last Post: 02-27-2008, 02:43 PM
