at 190,00 lost reverse and first installed reman trans evrything bolted up fien cannot find any adjustment on shifter cable i can adjust nuetral start switch and the motor will crank but the cable is approx 3/4 of an inch to long any thoughts would be appriciated ive done gm repairs my entire life firrst experience with a 4l60e though
Check out the info here: http://shbox.com/trans/A4_trans_linkage.html
There is no way to happiness....happiness is the way.
High Desert SoCal
93 K1500 burb (personal) 350 AT 3" Lift 250K+
02 Honda Civic LX
Looking for a 1990's Miata for an engine swap
Make sure you use the original shift linkage that bolts to the transmission as there are more than one and they look the same. Follow the directions on the link that was posted and you should be able to adjust it. Did the reman look exactly the same as the old transmission?
Jim
2004 SILVERADO 2500HD LS
Pro Comp Leveling Kit
Pro Comp Programmer
Bilstein Shocks
Linux Bed Liner
Tinted Windows
Other rides:
1967 Landcruiser <350 Chevy>
1970 Camaro
1990 Geo Metro Convertible
2007 FJ Cruiser
turned out somebody had put aftermarket cable with no adjustment in cable new delco cable and adjust easily the real kicjker is installed everything checked fluids fired my truck up and the trans pump let go everybody told me never trust a reman but ive had good luck untill now![]()
You may not have indexed the torque converter all the way into the pump. Did the converter turn easily before you bolted it up? Sorry to hear you have to pull it back out. This is the main pitfall of buying a reman. Many reman companies will have yo take it to a local shop for repair if the failure is their fault.
Jim
Pro Comp Programmer
Bilstein Shocks
Linux Bed Liner
Tinted Windows
Other rides:
1970 Camaro
2007 FJ Cruiser
Happens to the best of us. I remember an episode of Monster Garage where they were in Iraq for a Humvee project, and they forgot to fill the converter before installing it and ruined the tranny and put a wet blanket on the project.
I hope your not soured on tackling tough projects like trans swaps.![]()
High Desert SoCal
02 Honda Civic LX
Bookmarks
