Results 1 to 4 of 4
Thread: Fuel Pump
    Newbie da pope is a glorious beacon of light
    Apr 2009
    Unhappy Fuel Pump
    Tried to start my Burb today and it will not crank. It sounds as though it is trying to start, but no sound from the fuel pump. Checked fuses, none are blown. The relay rattles when shaken. My fuel pump is loud and you can here it when you turn the switch to the on position. There is no sound now. Is there another fuse box besides the driver door and driver side engine? How are the fuel pump fuses labeled, we may be missing something? Or, is it truly the pump? Any help!!!!! Driving Jeep and not happy!!!!
    Sr. Apprentice Z07 is a glorious beacon of light
    Aug 2009
    The fuel pump is powered via two parallel circuits. One is from the computer through the FP relay. This is powered when the key is set to run and again when the comp detects engine start. The comp will keep power to the FP through the relay until engine shut off. The other circuit is through the oil pressure sending switch. This will power the FP once it detects oil pressure greater than 4PSI. Typically if a FP relay fails the engine will still start if you crank it long enough for the starter to turn the motor and therfore the oil pump to produce that 4 PSI min.
    As a test you can look for other relays on your burb that are the exact same as the FP relay but for non-critical systems like AC or horn etc. and swap them. You can also disconnect the oil pressure sending switch from the wire harness and jumper the harness connector. This will power the FP from the time the key is turned to on until it is turned to off.
    There is a persistant myth out there that the fuel pump will be turned off if the oil pressure drops. There never was any truth to this myth what-so-ever.
    If you do replace the pump be sure to replace the sock too. The best thing you can do to promote FP longevity is never run less than 1/4 tank of gas. The pump is cooled by the gas that covers it.
    Legend 2COR517 has a reputation beyond repute
    May 2009
    Maine
    Does the truck run on ether? Although it certainly sounds like your pump is not working, could be ignition. Ether would rule that out. Also, give the bottom of the tank a good whack with a mallet or hammer, right in the middle. That might get the pump to start.
    Master Mechanic tattooed4life is a splendid one to behold
    Apr 2008
    Stevensville MI
    Sounds like all the rest.............dead pump blues. I had my gf cycle the key on mine while I had my ear against the tank just to verify there was no pump noise. I also did all of the prelim tests before I pulled my tank. In the end it was no pump sound and I was dead in the water.
    1997 Chevy K3500
    4x4 X-Cab Dually
    454 Dual Exhaust
Similar Threads
  1. Is it my fuel pump
    By treysanatomy in forum Chevy C/K Truck Forum
    Last Post: 02-06-2010, 04:10 PM
  2. Fuel Pump & FPR Didn't fix!HELP!!!!
    By tahoe freak in forum General Chevy Tech Q&A
    Last Post: 12-08-2008, 01:56 AM
  3. Twitching/vibrating fuel gauge - Not the fuel pump assembly.
    By Springthing in forum Audio / Video Electrical
    Last Post: 09-26-2008, 06:10 PM
  4. Fuel Gauge sender/fuel pump Together-seperate???
    By TahoeCrowe in forum General Chevy Tech Q&A
    Last Post: 09-05-2008, 03:55 PM
  5. New gal with fuel pump ???'s
    By ymisoqt in forum Member Introductions
    Last Post: 09-02-2008, 09:59 PM
