our 2006 1500 has a tailgate that won't close unless you really slam it or repeatedly slam it. The handle mechanism will open the tailgate ok. Two things: is something adjustable where the tailgate latches to the truck? Also, the handle doesn't make the latches (on either side of the tailgate) move when you work the handle, could something be sprung or broke, or should they move?
Maybe the latch on the side of the tailgate is just stuck... spray it with some lube to loosen and then apply some grease? white lithium grease?
2008 Chevrolet Silverado 1500 LTZ 5.3L EC/Std Bed 4x4 Flexfuel
Full Metal Jacket Spray on Bed Liner
Black Powder coat Diamond Plate Weatherguard Tool Box
Corsa Performance Sport Exhaust System
K&N Flat Panel OEM replacement Air Filter
Bridgestone Dueler A/T Revo tires P275/55/R20
Black Reflective pinstripe and VORTEC hood lettering
Billet front bowtie
Rear Bowtie Delete
Blue strobe grille lights
Blue strobe rear window lights
Blue LED Mini Light bar in front Grille
I sprayed one of the latches to no effect. Its like there is no spring action to it. I know the latch connects to the center handle because we can open the tailgate if it indeed closes. Maybe one side works and the other side does not?
Just how difficult is it to spray the center handle mechanism or worse, replace it?
shouldn't be too hard... people replace them with aftermarket ones all the time
Billet front bowtie
Rear Bowtie Delete
This was just a case of a rusty mechanism. Once we sprayed the tailgate release handle mechanism with WD40 the tailgate closes with no effort at all. You don't need to slam it shut at all, just make contact and it latches fine. Thanks for the suggestions, but this fix turned out to be a simple lube job.
I knew that's all you needed lol
Billet front bowtie
Rear Bowtie Delete
i recently had the same problem with mine, and the latch on the tailgate was bent as well as the pin that the latch latches to was too
2000 silverado with a 5.3l v8, shorty headers, upgraded plugs, 10 mil wires, magnaflow high flow cats, flowmaster 80 series muffler(2 in 2 out) w/ 18 inch stainless silverline tips. i have a k&n CIA. its a 4x4 z71 offroad package. Ls model.
extended cab 160k miles, truxedo low profile bed cover, diablo sport predator tuner.
reman tranny @ 130k miles
Chris
It's the latches. Clean them, grease them up and make sure they are not bent.
2007 Silverado 1500 LTZ Extended cab 4x4 5.8 ft bed
Exterior: Black
Interior: Light Titanium/Dark Titanium Accents
Features: Auto-Dimming Inside Rearview Mirror, Power Door Locks, Power Sunroof w/Express-Open, Power Windows w/Driver Express-Down, Power folding side view mirrors w/blinker arrow, Radio: AM/FM Stereo w/MP3 Compatible 6 Disc CD Player, XM Satellite Radio, On-Star
Bookmarks
