My 05 Suburban actuates the power door locks just after the engine is turned on. So this is a problem waiting to happen because we usually turn the engine on to get the AC running then get the kids buckled up in their seats. If I close the drivers door, the locks are actuated then I close the rear door, I am locked out. Right now, we always roll the drivers window down just in case the door closes.
Is there a way to change when the locks actuate such as when I take it out of park (like my Equinox)?
I have considered the spare key route, and buckling everyone up before turning on the truck...just want an option if possible.
tks.
Tom -
2005 Suburban 4x2
2005 Equinox LT AWD
Hope this helps:
Document ID# 1883178
Subject: Disabling Auto Door Locks - keywords dic ipc lock manual mode operation program reprogram unlock #PIT3189E - (12/21/2006)
Models: 2005-2007 Cadillac Escalade, Escalade ESV, Escalade EXT
2005-2007 Chevrolet Avalanche, Suburban, Tahoe
2005-2007 Chevrolet Silverado, Silverado Classic
2005-2007 GMC Sierra, Sierra Classic
2005-2007 GMC Yukon, Yukon Denali, Yukon XL, Yukon Denali XL
The following diagnosis might be helpful if the vehicle exhibits the symptom(s) described in this PI.
Condition/Concern:
Some customers may comment that they are unable to override the automatic door locking feature. In prior model years, customers were able to select "Doors Lock Manually" from the DIC. However, starting in the 2005 model year, this selection was removed.
Recommendation/Instructions:
Since the 2005 model year, all BCM's (Body Control Modules) are programmed from the factory to allow two personalized door lock settings:
Setting 1: All doors lock when the transmission is shifted into gear.
Setting 2: All doors lock when the vehicle speed is greater than 8 mph (13 km/h).
New BCM calibrations have been released for the 2006 and 2007 model years to allow a Setting 3: No Automatic door locking (Manual). This setting should ONLY be turned on at the owner's request. At this time there is NO new calibration available for the 2005 models or vehicles with manual transmissions. Use one of the following procedures below to disable the auto door lock feature.
Use the following procedure to turn on this feature for models:
2006 Cadillac Escalade, Escalade ESV, Escalade EXT
2006 Chevrolet Avalanche, Suburban, Tahoe
2006-2007 Chevrolet Silverado Classic
2006-2007 GMC Sierra Classic
2006 GMC Yukon, Yukon Denali, Yukon XL, Yukon Denali XL
Reprogram the BCM with updated calibrations currently available in Tis2Web. When at the "Calibration Selection" screen in Tis2Web select the "locking" tab and pick the calibration listed "auto door lock option enabled on dic".
On vehicles with Steering Wheel Controls (RPO UK3) use the controls to scroll through the personalization setting to the "Auto Door Lock" feature. There will be a new "Manual" selection now available to choose, along with the two previous selections "In Gear" and "With Speed".
On vehicles Without a Steering Wheel Controls (RPO UK3) use the owners manual to enter the door lock programming mode in section
Once in the programming mode press the lock side of the drivers power door lock switch, you will hear either one, two or NO chimes. One chime indicates you are in Setting 1 (lock in gear), Two chimes you are in Setting 2 (lock with speed) and NO chimes you are in Setting 3 (Manual). Continue to press the door lock switch to scroll through the 3 different selections until you hear the desired setting and then exit the programming mode by turning the ignition key on.
2007 CadillacEscalade, Escalade ESV, Escalade EXT
2007 Chevrolet Avalanche, Silverado, Suburban, Tahoe
2007 GMC Sierra, Yukon, Yukon Denali, Yukon XL, Yukon Denali XL
On vehicles equipped with steering wheel controls (RPO UK3) DIC (Driver Information Center) control buttons are included. Use the DIC buttons to scroll through the personalization settings to the "Auto Door Lock" feature. There will be to two different settings: "Lock with speed" or "Lock in gear". You will notice there is NO new setting but also there will be no "check marks" next to any of the settings. This means the auto door lock feature is disabled. If there is a "check mark" next to one of the "Auto Door Lock" selections then the only way to remove the "check mark" is to scroll to "Factory Settings" and select "Restore", this will remove the "check mark" thus disabling the "Auto Door Lock" feature.
Note: Please keep in mind that if "Factory Settings Restored" is selected it will change all of the other personalization settings back to the factory settings and they will need to be reset back to the owners settings.
On vehicles without the DIC control buttons once the BCM is reprogrammed with the new calibration the "Auto Door Locks" will be disabled and can not be turned back on unless the BCM is reprogrammed back with the previous calibration.
Please follow this diagnostic or repair process thoroughly and complete each step. If the condition exhibited is resolved without completing every step, the remaining steps do not need to be performed.
There is no way to happiness....happiness is the way.
High Desert SoCal
93 K1500 burb (personal) 350 AT 3" Lift 250K+
02 Honda Civic LX
Looking for a 1990's Miata for an engine swap
Thanks unplugged. I will give this a try.
Tom -
2005 Suburban 4x2
2005 Equinox LT AWD
First thing to do is to make sure the power door locks work. You can do that by locking and unlocking the doors using the power door lock switch on the main door switch. If they lock and unlock, then we have a Remote Keyless Entry (RKE) problem. If they don't, you have a power door lock problem.
Next, try to reset the transmitter ID code in the RKE module.
The door lock operation is correct using the door controls.
As a side note, I bought the truck w/o a key fob. Bought a used one on ebay. The door locking problem was occurring before I bought the key fob.
Tom -
2005 Suburban 4x2
2005 Equinox LT AWD
Bookmarks
