Results 1 to 2 of 2
    Default please help with lighting issue
    98 silverado 4x4, my fuel pump recently died,after changing it my lights were alittle funny. Right after i changed it my my dash would light up everytime i pressed the brake, went away on its own quicly, then i noticed i had no rear running lights. all the other lights work still. i checked the bulbs, fuses, and connections, everything was good. turns out im not getting power at the rear connection(underbox, connects rear lights to wires running from front). Any ideas on where to start looking for problems? I will be tracing the wires as far as i can once i have the time, it was too dark to start that now. Any suggestions?
    98 Silverado
    5.7 vortec
    14 bolt posi rear, with 373s
    3"body?1.5"susp.
    33" wild countrys
    tube steps, chrome kit, fenderflares,
    chrome diff plate, window flares,
    2-10"Alpine TypeE, Alpine 450watt V-Power.
    Master Mechanic tattooed4life's Avatar
    Apr 2008
    Stevensville MI
    I don't know what you would have touched while changing the pump that would cause that kind of issue. I would start by checking any wires or new connections you made while changing the pump. I had issues with fuel gauge not working after changing my pump. I removed the ground wire from the tank and sanded it and it worked fine. Retrace your steps of installing, maybe a harness came unplugged or just loose. Good Luck.
    1997 Chevy K3500
    4x4 X-Cab Dually
    454 Dual Exhaust
  1. Hid/led lighting
    By BMP0014 in forum Chevy Truck Accessories
    Last: 05-29-2010, 01:21 PM
  2. lighting problem. =[
    By blacknight97 in forum Chevy Silverado Forum (GMC Sierra)
    Last: 04-25-2010, 03:54 PM
  3. Exterior lighting
    By drumrob in forum Chevy Truck Accessories
    Last: 03-16-2009, 05:58 PM
  4. Lighting issue
    By nsdread07 in forum General Chevy & GM Tech Questions
    Last: 03-10-2009, 11:17 AM
  5. new lighting? yes or no?
    By cascott325 in forum Chevy Truck Accessories
    Last: 09-16-2008, 10:54 PM
