Page 1 of 3 123 LastLast
Results 1 to 10 of 21
    Sr. Mechanic chevyman2004's Avatar
    Jul 2009
    southwest Minnesota
    Default What tire pressure to run on load "E" tires?
    I have a 2004 Silverado 2500HD with Laramie Performer tires load E with a max 80 psi. What tire pressure should i be running in them unloaded and loaded? I have been running them at 70 psi unloaded, is this wrong?
    2004 Chevy Silverado 2500HD:sign0011:
    6.0L Vortec
    Magnaflow 4" Dual Exhaust
    Leveling Kit
    Westin step bars
    Penda Skid Resistor bed liner
    dark blue metallic
    Bak Industries plastic bed rail caps
    Alpine 6 1/2" SPS-600 in front
    Alpine 6 1/2" SPG-17C2 in rear
    Bilstein HD Shocks front and rear
    Goodyear Wrangler Duratracs LT265/75/R16
    Access Lorado Roll-up soft tonneau cover
    If you are not "loading" it down, I'd keep the pres. @ 45 psi. It rides better and your tires will probably last longer. Also, there should be a "tag" on the door post that tells you what pres. to run. Good luck!
    2010 Z/71 Colorado C/C
    Black 4X4 w/5.3L V8
    2007 Winnebago Adventurer
    w/8.1L Chevy & Allison 6spd.
    Canyon Lake, Texas
    You are much to high at 70 PSI.
    See post 11
    http://www.gmtruckclub.com/forum/sho...ighlight=weigh
    Jr. Engineer moosetags's Avatar
    Jan 2008
    Santa Rosa Beach, Florida, in the Florida Panhandle, so far out that we are in the Central Time Zone
    I have two 2500 Suburbans, an '04 and an '05. Both have load range E tires. The driver door sticker shows that the rear tire pressure at 80 psi and the front tires at 50 psi.
    When not loaded or towing, I am running 70 psi rear and 50 psi front.
    When towing my Airstream (7400#/900# tongue weight), I run 80 psi rear and 70 psi front because an anti-sway/weight distribution hitch system is in use. This shifts weight to the front axle to equalize the load and level the truck.
    Keep in mind that load range E tires are 10 ply and somewhat stiff. D's are 8 ply and C's are six ply. E's are designed to run at these higher pressures. I wouldn't run E' at anything below 50 psi.
    Brian
    Brian McCabe
    '05 Yukon XL 2500 Quadrasteer
    '11 Silverado 3500
    I agree with Moose 100%. I run mine the same way unloaded and loaded
    One of the easiest ways to find where you should be running your tires is to draw heavy chalk lines across the pavement in front of the tires then roll the truck over the chalk lines and check the findings.
    Chalk line on outer edges and not the center to low pressure.
    Chalk lines across the center and not the edges to high pressure.
    Chalk line evenly across the tire pressure is right.
    In this case since your wanting loaded and unloaded pressures you'll need to load the truck and find the pressures, then do the same method unloaded.
    Record your pressures for future use.
    When using this method you'll notice all four tires will probably end up with different pressures, this is because the load at each tire is different.
    Those obviously arent the factory tires, find what the manufacturer says
    Hypertech III, K&N, true dual
    285/75/16
    ___________________________
    Jason
    Sr. Engineer nickgiacalone's Avatar
    Mar 2009
    Metro Detroit, MI
    i have load range e tires from the factory on my 09 2500 silvy and i run my tires at the manufacturers suggestion....i keep them at 80 out back and 60 in the front, i do not change the air for loaded or unloaded
    -Nick
    2013 Silverado 1500 4x4 LT, Z71 Appearance Package, Vortec 5.3L AFM
    Victory Red, Ebony Cloth
    Custom pin striping, Bed Rail Protectors, GM Bed Liner, Husky Liner Floor Liners, Tint, Wade In-Channel Window Visors, Tractor Supply Black Low Profile Toolbox
    Jul 2009
    southwest Minnesota
    I've looked all over the web for info on Laramie tires but there isn't much info on them and i did the chalk line thing and there was chalk in the middle so i will dial it down to 50 psi and see how that goes. thanks for the help.
    6.0L Vortec
    Leveling Kit
    Westin step bars
    dark blue metallic
    On both of my 2500HD's I run 45 lbs. unloaded, and then when we tow the car trailer we never go more than 60 lbs. We had 80 lbs. in them one time, and they looked like they were going to explode! Our certified ASE mechanic told us he would never put 80lbs. in an unloaded truck tire I don't really think there is a constant answer in this matter, I think it is personal preference and what works for you.
  1. Stock "P" rims safe with "LT" tire pressure?
    By xycarp in forum Wheels & Tires
    Last Post: 05-31-2010, 09:38 AM
  2. Replies: 15
    Last Post: 01-02-2010, 08:51 AM
  3. NOLA Region and looking for 255 70R16 "pull off" tires
    By OE812 in forum LA - Louisiana Chevy Truck Forum
    Last Post: 04-29-2009, 07:10 PM
  4. Replies: 0
    Last Post: 06-21-2008, 12:30 PM
  5. "Monster Mash" Singer Bobby "Boris" Pickett Dies At 69
    By Cableguy in forum The Coffee Shop ~ Chit Chat
    Last Post: 04-27-2007, 10:47 PM
