Results 1 to 7 of 7
    Jr. Apprentice jicurtis is a glorious beacon of light
    Aug 2008
    Broomfield, Colorado
    Default Gas or exhaust smell since I started towing my trailer 2 weeks ago
    I purchased a new travel trailer 2 weeks ago, pulled it about 1200 miles. On returning, I have a very strong gas smell inside the passenger compartment. It gets worse if I have my window down or the passenger window down. I have looked underneath, nothing dripping. I have smelled the exhaust pipe, doesnt seem to be that. I have looked under the hood, but I cant find anything that looks unusual. I found that if I put the outside air on high fan it doesnt seem to smell which leads me to believe it is coming in from the back window. Has anyone had a similar problem.
    I have a 2008 1500 Suburban 4WD 5.3L 3.73 rearend, Equal-i-zer hitch, trailer weighs about 6000 wet with all of our stuff, pulls fine, but only 10mpg while pulling, 20 mpg without trailer.
    Jim
    Legend unplugged has a reputation beyond repute
    Sep 2006
    High Deserts of SoCal
    Any DTC codes? What is the color of the tailpipe? brown, black etc. Is the smell there only when you tow or all the time?
    There is no way to happiness....happiness is the way.
    http://kx6ijq.blu.livefilestore.com/y1pcOFVNH4ix1hjyGUVyXK5LRfef7qSeWzlZDorpQhIEfkZ2ZA  _vXMYypuKMJFw671uF2ZPhjez_j-atRmcjM2zQKpQi1JSsB75/burb1.JPG
    High Desert SoCal
    93 K1500 burb (personal) 350 AT 3" Lift 250K+
    02 Honda Civic LX
    Looking for a 1990's Miata for an engine swap
    Aug 2008
    not sure howto get DTC codes? Originally I thought it was only pulling camper, but now it seems to be there most of the time, sometimes worse than others. it really has me baffled! The inside of the tailpipe is black with very small white specs??
    Legend vncj96 is a name known to all
    Feb 2008
    Red Wing, Minnesota, United States
    1 Post(s)
    i would think you would be getting a code, but this sounds like the charcoal canister and its components. The system recyles gas vapor into a chacoal canister and then releases it into the engine to burn it off. Mine did it a while ago and it eventually just went away fter i played with the lines so one of them must have been loose
    5.7 K&N & True Dual Exhaust
    Hypertech III
    05 17" Silverado rims
    99 LS 1500 5.3 "THE MULE"
    Reg Cab Long Box
    285/75/16E Dunlop Rover M/T
    ___________________________
    Jason
  5. #5
    Legend tbplus10 has a reputation beyond repute
    Mar 2007
    -97.0482020 N, 32.6625890 W
    1 Post(s)
    1 Thread(s)
    On a 2008 I wouldnt even lift the hood it should be covered under warranty and I'd have it back at the dealer right away.
    Sounds a lot like the evap cannister has a loose line, your fuel system is a closed pressurized system and even a pinhole leak in a line will dump lots of fuel fast.
    Tim
    2011 Silverado 1500 LT
    2008 HHR LT
    1999 Tacoma SR5 TRD 4X4
    1993 Jeep Wrangler
    1991 Toyota Rock Crawler
    2009 Harley Davidson Nightrain
    2004 Harley Davidson FLHT "Bagger"
    2003 Glastron GXL Bowrider
  6. #6
    Jr. Engineer moosetags is a glorious beacon of light
    Jan 2008
    Santa Rosa Beach, Florida, in the Florida Panhandle, so far out that we are in the Central Time Zone
    I have pulled travel trailers for years, and you will get less mpg when towing, but going from 20 mpg down to 10 mpg is way too much of a differential. Something is amiss.
    Brian
    Brian McCabe
    '05 Yukon XL 2500 Quadrasteer
    '11 Silverado 3500
  7. #7
    Aug 2008
    I finally got it fixed today. You are not going to believe it, but it was the lubricating fluid in my rear end ! They had to completely flush out all of the rear end lube, relocate the vent tube, add a filter, and replace the fluid with a different fluid. There is a tech bulletin on it. Now I can be proud of my burb once again.....
    I know it is hard to believe, but trust me, this did fix it!
    It appears to affect only 07 & 08 burbs, mine is an 08 LT2 with the G80 rearend...
Similar Threads
  1. Towing a car trailer
    By nos351wcm in forum General Chevy Tech Q&A
    Last Post: 05-02-2010, 11:08 PM
  2. Raw Gas smell in exhaust
    By xjoedx in forum Performance & Fuel
    Last Post: 04-01-2010, 04:12 PM
  3. Towing a trailer
    By METZCOOL in forum Chevy Suburban Forum (GMC Yukon XL)
    Last Post: 08-24-2009, 08:32 PM
  4. Towing a trailer
    By METZCOOL in forum General Chevy Tech Q&A
    Last Post: 08-05-2009, 01:06 AM
  5. Smell when towing
    By gudtym charky in forum Chevy Silverado Forum (GMC Sierra)
    Last Post: 11-04-2008, 06:07 PM
