    Default AC compressor clutch
    I have a 97 Savana and the other day the compressor clutch smoked, alot.
    What are the chances it is only the clutch and not the compressor that actually caused this to happen.
    Does anyone have advice on how I can find out if it is just the clutch and not the compressor?
    How do you get the clutch off?
    Bill Davis
    If the compressor is turning and blowing cold air it's working. If the clutch is slipping and the compressor won't turn over then it probably failed. Remove the belt and see if the compressor will turn over. Auto zone will loan you a puller to change the clutch.
    Jim
    2004 SILVERADO 2500HD LS
    Pro Comp Leveling Kit
    Pro Comp Programmer
    Bilstein Shocks
    Linux Bed Liner
    Tinted Windows
    Other rides:
    1967 Landcruiser <350 Chevy>
    1970 Camaro
    1990 Geo Metro Convertible
    2007 FJ Cruiser
    If I remove the belt how do I determine if the compressor will turn over.
    My fear on this is that I will replace the clutch only to find out the compressor locked up and is actually what caused the problem. It was working fine before the clutch smoked, and when I say smoked I mean a lot of smoke, I could actually hear it cracling like a camp fire.
    Bill
    If the compressor froze up there's no way you can turn it. Take the belt off and be creative. I have a belt wrench and a vice grip chain wrench. Do you have any tools like this?
    Yes I can do those things.
    I went and bought a clutch and rented a puller. The thing is I see how to use the puller to get the clutch off but not how to use it to put the new one on. Any advice?
    Bill,
  1. A/C Compressor Clutch Bearing Removal
    By Vassili in forum General Chevy & GM Tech Questions
    Last: 06-07-2010, 04:07 PM
  2. clutch job
    By bucklti in forum GM Powertrain
    Last: 03-05-2010, 08:42 PM
  3. AC compressor/clutch squeal
    By jos1ah in forum Chevy C/K Truck Forum
    Last: 12-20-2009, 10:32 PM
  4. How do I know if my fan clutch is bad?
    By OldPitPony in forum General Chevy & GM Tech Questions
    Last: 09-27-2009, 10:17 PM
  5. Fan Clutch help
    By Dr_Zero in forum Chevy Suburban Forum (GMC Yukon XL)
    Last: 03-30-2007, 08:18 AM
