Results 1 to 4 of 4
Thread: LH6 vs L76
    Jr. Apprentice Jeremy09LTZCrew is a glorious beacon of light
    Jun 2009
    Seattle, WA
    Default LH6 vs L76
    Both engines have the VVT and AFM and both are small blocks. However, one is the 5.3 and the other is the 6.0. So my question is: What exactly is the mechanical difference between these two?
    Jeremy - 29
    2009 Chevroley Silverado Crew Cab 4x4 LTZ 5.3
    Mods to come!!
    Sr. Engineer azdrtdog is a glorious beacon of light
    Apr 2009
    phx.
    my first guess would be bore n stroke same as 5.0 n 5.7
    99 tahoe 2 dr. 4x4 7.4 4L80-e NP246, SAS, dana 60 hp, sterling 10.5 rear, gibson headers, and alot of tricks of the trade !!!!!!IF YOU'RE NOT CHEATING YOUR NOT TRYING!!!!!!!!
    Legend vncj96 is a name known to all
    Feb 2008
    Red Wing, Minnesota, United States
    1 Post(s)
    Most "family" motors are just bore and stroke. The 3X00 series is the same, a 3.1, 3.4, and 3.8 are all the same sized block, just different bore and stroke, and in the case of the 3.8 heavier internals being that it easier to make one block a SC then the next one on the line NA, instead of having two seperate lines.
    5.7 K&N & True Dual Exhaust
    Hypertech III
    05 17" Silverado rims
    99 LS 1500 5.3 "THE MULE"
    Reg Cab Long Box
    285/75/16E Dunlop Rover M/T
    ___________________________
    Jason
    Legend 5speedsilverado is a glorious beacon of light
    Mar 2009
    peoria arizona
    the block is different to accommodate the bigger bore
