Page 1 of 2 12 LastLast
Results 1 to 10 of 20
    Sr. Apprentice Restlessone is a glorious beacon of light
    Feb 2009
    Default Transmission flush
    I would like to hear opinions on when and if you should flush out the transmission and put in new fluid. This my first auto so I have no experience with auto transmissions.
    I just purchased an 07 sliverado 4x4 with 72,000 km (45,000 miles). I'm being told by "people" that it is overdue for a flush. Is this true, what fluid is favoured?
    Thanks
    Gordon
    Legend
    99'HEARTBEAT has a reputation beyond repute
    Apr 2009
    2 Post(s)
    For my ride,I do a Flush every 30K,or there about.I tow a boat during the Summer.I just feel better knowing that I have done all I can to keep My Trans Running Strong.With 72K miles on your trans I would said it is Due for a Flush and new Filter.
    MIKE
    99".....SILVERADO....5.3 LITER / 3.73
    Legend Jimmiee has a reputation beyond repute
    Feb 2009
    Reno, Nevada
    The word "flush" is a misnomer and should not be taken in the literal sense. A true flush where chemicals are used should never be done as it can cause problems by swelling seals and dislodging debris which can doom a perfectly working transmission.
    What transmissions need is servicing. If servicing is done on schedule there is no need to flush or change all the fluid. The average transmission holds 10 - 14 quarts. A service only replaces 4 or 5 quarts along with the filter.
    If your transmission has been neglected and the fluid is turning dark brown then a "flush" or fluid exchange is in order. This can be performed at home with a length of rubber hose and a 5 gallon bucket. This method although messy at times replaces all the fluid just as a fancy machine does at a repair shop or quickie lube.
    Always drop the pan and change the filter before flushing the system. Once the filter is changed and the pan replaced the procedure is as follows:
    Remove the return line from the trans at the radiator. Ususlly but not always the top line.
    Attach a rubber hose to the outlet and into a bucket.
    Fill the trans with 6 quarts of fluid.
    Start the vehicle and as the old oil comes out add oil to the transmission a quart at a time.
    Note that the new oil is picked up into the filter and displaced into the torque converter. So the oil you remove is a 50/50 mix of old and new oil. A dirty transmission may take 15 or more quarts of oil to get the oil clean and red looking.
    Jim
    2004 SILVERADO 2500HD LS
    Pro Comp Leveling Kit
    Pro Comp Programmer
    Bilstein Shocks
    Linux Bed Liner
    Tinted Windows
    Other rides:
    1967 Landcruiser <350 Chevy>
    1970 Camaro
    1990 Geo Metro Convertible
    2007 FJ Cruiser
    Legend
    Apr 2009
    2 Post(s)
    Very Good Infor!!!!....... Jimmiee
    MIKE
  5. #5
    Feb 2009
    Reno, Nevada
    Quote Originally Posted by 99'HEARTBEAT View Post
    Awww shucks!!!!!
    Thanks!
    Jim
    Pro Comp Programmer
    Bilstein Shocks
    Linux Bed Liner
    Tinted Windows
    Other rides:
    1970 Camaro
    2007 FJ Cruiser
  6. #6
    Legend
    Apr 2009
    2 Post(s)
    Quote Originally Posted by Jimmiee View Post
    Awww shucks!!!!!
    Thanks!
    Well All I know is that if I have a Problem with my Trans,I'm talking to you 1st.
    MIKE
  7. #7
    Feb 2009
    I don't think the transmission has been neglected. The manual calls for servicing at 80,000 KM and I'm only at 73,000 KM. I just wondered what conventional wisdom was.
    Thanks for the input.
    Gord
  8. #8
    Legend 2COR517 has a reputation beyond repute
    May 2009
    Maine
    As usual, Jimmiee is right on the nose. If you have enough hands, you fill through the dipstick you pump out the old.
  9. #9
    Jr. Mechanic nos351wcm is a glorious beacon of light
    Aug 2009
    what fluid should be used? i have 105,xxx miles on my 2000 1500. the trans could use a "flush." also how many quarts should i get? thanks
    Cheers from NJ
  10. #10
    Feb 2009
    Reno, Nevada
    Quote Originally Posted by nos351wcm View Post
    Cheers from NJ
    Use a good Synthetic that's Dextron compatible. To get brown / amber looking fluid red again you will need about 15 quarts. You can stop at 10 or 12, whenever the fluid turns red. The darker brown the fluid is the more clean fluid you will need. I have seen a bad 4L80E use 22 quarts to get it clean!
    Jim
    Pro Comp Programmer
    Bilstein Shocks
    Linux Bed Liner
    Tinted Windows
    Other rides:
    1970 Camaro
    2007 FJ Cruiser
Similar Threads
  1. Radiator flush
    By Bobby1021 in forum General Chevy Tech Q&A
    Last Post: 01-22-2010, 07:59 PM
  2. need a flush floor
    By yoshi in forum Chevy Truck Accessories
    Last Post: 11-03-2009, 11:43 AM
  3. Transmission Flush Instructions...
    By 1st Synthetics in forum 1st Synthetics
    Last Post: 05-08-2009, 12:59 PM
  4. tranny flush
    By will454 in forum Chevy Suburban Forum (GMC Yukon XL)
    Last Post: 05-04-2009, 04:04 PM
  5. Transmission Flush
    By bzboardco in forum General Chevy Tech Q&A
    Last Post: 01-15-2009, 04:16 PM
