Results 1 to 2 of 2
    Sr. Apprentice rowekmr is a glorious beacon of light
    Nov 2007
    Default Drivetrain ques 99 Suburban 2500 4x4
    Hello
    I recently got a high mileage (200K) 99 Suburban 2500 4x4 with the 7.4L engine and push button automatic 4x4 dash switch for occassional towing of a boat and travel trailer? Does this have the 4L80E trans? Which transfer case does it have? Mines is making a metallic dragging noise when driving slow and will need some attention and everyone asks which TC does it have and I don't know. Can that sound be from low fluid or is it mechanical destruction going on inside? It is in 2wd when I drive I believe becauese it doesn't bind when the steering wheel is turned to the limits when driving. Some have asked is it stuck in 4wd.
    Thanks
    Joe
    06 Explorer Ltd 4x4
    Sr. Engineer azdrtdog is a glorious beacon of light
    Apr 2009
    phx.
    if you have the push button WITH the auto option its a np 246 if its a push button without its most probly a 241. THE 246 is the only auto trans used in 1/2 and 3/4 ton trucks changing only the input gear for the 4l80 and smaller 4l60 the worst thing about the 246 is the front output is on clutches and you smoke em bad pulling in reverse
    99 tahoe 2 dr. 4x4 7.4 4L80-e NP246, SAS, dana 60 hp, sterling 10.5 rear, gibson headers, and alot of tricks of the trade !!!!!!IF YOU'RE NOT CHEATING YOUR NOT TRYING!!!!!!!!
Similar Threads
  1. 1969 GMC 3/4 ton needs drivetrain!
    By MMS1781 in forum Chevy C/K Truck Forum
    Last Post: 06-04-2010, 07:31 PM
  2. ques about torsion key
    By joshhungerford in forum Lifted & Offroad Suspension
    Last Post: 03-25-2010, 09:34 PM
  3. Drivetrain delay
    By sphillips in forum Powertrain
    Last Post: 11-15-2009, 01:19 PM
  4. 93 suburban 4x4 drivetrain question UDATE
    By E34felix in forum Chevy Suburban Forum (GMC Yukon XL)
    Last Post: 10-26-2008, 06:40 PM
  5. 93 suburban 4x4 drivetrain question
    Last Post: 10-22-2008, 12:02 AM
