    Sr. Apprentice mashburn's Avatar
    Apr 2009
    cedar hill,tx
    Default Projectors and HID's
    i have a hid kit on my truck the question is if i get a set of aftermarket projector head lights can i my hid bulbs or are the projectors seal
    im looking at something like these
    http://www.carid.com/product.php?pro...t=69390&page=1
    Jr. Mechanic Blazerado's Avatar
    Apr 2009
    The Dena, Maryland
    You should be able to use your HID's with the new lights. I havent seen any projector headights that are sealed beam. Just make sure that the bulb sizes are the same.
    Blazerado is right about the bulb size, there is an aluminum holder inside of the headlight that is about 2" thick to snap the base of the bulb into. Most of the aftermarket projector headlights have either a H3 or H1 bulb, so if you have the 9005/9006 it won't work with those. I just saw someone that tryed to do that on another forum, and he ended up ordering the correct bulb type in HID because he couldn't cut through the aluminum holder. Good luck!
    X2. You should be able to change the bulb. Most people recommend changing to H.I.D. Bulbs if you get Halo Projectors because the stock bulbs that come with the projectors don't light up too much.
    Silverado Single Cab 2008 Subwoofer/Audio Build - http://www.gmtruckclub.com/forum/showthread.php?t=26310
    -12" AQ HDC3
    -Custom Downfiring Box Tuned To ~37 Hz
    -Diablo Audio Technologies HellFire 1000.1 (1000 Watts RMS)
    -Pioneer DEH-P5000UB, 4GB Flash Drive
    All In A 2008 Single Cab :gasp:
    Apr 2009
    cedar hill,tx
    Ok thanks guys so im guessing i just need to order some shorter bulbs and i will be good to go...thanks again
  1. Aftermarket Projectors + HID Lights = Bad Idea?
    By ИorτнRoαdΛĸ907 in forum Lighting Discussion
    Last Post: 08-23-2010, 06:06 PM
  2. HID's
    By 04chevtruck in forum Lighting Discussion
    Last Post: 03-29-2010, 10:56 AM
  3. '99 Chevy Suburban HID and Projectors
    By rivera5130 in forum Chevy Truck Accessories
    Last Post: 02-10-2010, 11:57 AM
  4. HID's
    By x1LSUTigerfan in forum Chevy Truck Accessories
    Last Post: 01-05-2010, 03:30 AM
  5. HALO Projectors Installed - Have a Look!
    By DaveyBoyo in forum Chevy Truck Accessories
    Last Post: 03-03-2009, 07:01 PM
