I just came back from LAX, while driving back to vegas the weather was nice and I opened the window, a terrible smell came in, I thought it was outside and about 10 minutes later the smell was gone so I didn't worry the truck was driving fine. I got home, open the door and sure enough it smelled the same( not coolant smell and not oil smell, the fluid is kind of "clear"), I look under the truck and there is some fluid all over the bottom of the truck, even a little inside the rear fender. the last few miles, when the truck was shifting from 1st gear to 2nd, it was giving a big kick..... I let the truck cool down for about 40 minutes, drove it arround and now it shift smoothly from 1st to 2nd. I check the trans fluid on the stick in the engine compartment and its full.
what could be my problem ?
Get the truck warm and let it idle in Park. Turn off the engine and quickly check the oil. It may be low and splashing up onto the stick.
Next get the trouble codes. When it shifted hard that tells me it went into failsafe and set a code.
What probably happened is you lost lock up and the fluid got hot. When this happens it will vent out and splash all over the bottom of the truck.
Also check the transfer case. If you park on a hill the oil may have run out of the transfer case and into the trans overfilling it.
The codes will be very helpful determining the root problem.
Jim
2004 SILVERADO 2500HD LS
Pro Comp Leveling Kit
Pro Comp Programmer
Bilstein Shocks
Linux Bed Liner
Tinted Windows
Other rides:
1967 Landcruiser <350 Chevy>
1970 Camaro
1990 Geo Metro Convertible
2007 FJ Cruiser
ok, i'll do that. i am at work today but should finish by 4 pm.i'll post the code. if it's just low on trans fluid, which one i need and where do you fill it up? i also had the service engine soon light that came on during the trip but i would think it's just a coincidence.
Jim
Pro Comp Programmer
Bilstein Shocks
Linux Bed Liner
Tinted Windows
Other rides:
1970 Camaro
2007 FJ Cruiser
oh.. i thought the service engine soon was just a "reminder" and not a " check engine" as of a problem.
Jim
Pro Comp Programmer
Bilstein Shocks
Linux Bed Liner
Tinted Windows
Other rides:
1970 Camaro
2007 FJ Cruiser
should i drain and replace with fresh transmission fluid knowing that it " overheat" ?if so, where is the drain bolt located, and how many quart will be needed?
Jim
Pro Comp Programmer
Bilstein Shocks
Linux Bed Liner
Tinted Windows
Other rides:
1970 Camaro
2007 FJ Cruiser
ok !
here are the codes:
P1870 Trans component slipping
P0161 02 heater circuit (bank2 sensor 2)
P0141 02 heater circuit (bank1, sensor 2)
and by the way, the fluid on the stick stink like crazy..
Bookmarks
