Results 1 to 2 of 2
    Sr. Apprentice CornhuskerChevy is a glorious beacon of light
    Aug 2009
    South Central Nebraska
    Default Light Questions
    I have been doing my research on aftermarket bulbs for my headlights. I drive an 07 Silverado NBS. I want more light, but dont want to break the bank, and I want simple, "plug and play" installation (I hate electrical stuff). So...I have seen to go with all the same brand. I would like to upgrade all of the lights, high, low, and fog, possibly running (are they different?) Do I go with LED, or Halagon bulbs...I also have seen HID/Xenon lights, but do you have to change wiring or anything like that to run those? Or do they just plug into the socket.
    Next question...Where can i find instructions for replacing the bulbs, I know it can't be hard, but I just got this pickup and don't care to mess somethin up by wingin' the install.
    Just found so much information on many different types and kinds that I wanted to clarify.
    Thanks
    2007 Z71 Silverado 1500 LT NNBS
    5.3L
    Custom Dual Exhaust
    2.25" ReadyLift
    285/65-R18 Kumho's
    Factory Steps
    Big Tex Cattle Guard
    Delta Pro Tool Box
    Chrome Door Handles
    WeatherTech Floormats
    Spray In Bedliner
    Sr. Engineer dsrtne1 is a glorious beacon of light
    Feb 2009
    Southern CA
    Lets see, if you want simple plug and play bulbs you could go with sylvania silverstars. Those are bright for halogen bulbs. Hid's are pretty simple. The kits come with a pair of bulbs and a pair of ballasts. You plug the wiring from the stock bulb into the ballast, wire from the ballast into the new bulb. And I myself have LED Daytime running lights but as for headlights I doubt they even make them in the correct bulb type and they certainly wouldnt have a strong enough light output. Replacing the bulbs is simple, just pop the hood and look behind the light housing and the bulbs should just twist right out.
    Michael, 17, CA
    2005 Silverado - See my garage for my mod list
Similar Threads
  1. Dome light and cargo light not working
    By Randy0702 in forum Chevy Truck Forum
    Last Post: 01-26-2011, 09:36 PM
  2. header questions? and other exhaust intake and tune questions?
    By elkosp16 in forum Performance & Fuel
    Last Post: 07-19-2010, 05:56 AM
  3. First time towing questions.. Tire psi/Air-bag questions
    By beforeiforget761 in forum Chevy Silverado Forum (GMC Sierra)
    Last Post: 05-16-2010, 08:39 PM
  4. 99 Chevy Silverado Map Light Dome Light OEM USED
    By Steve in forum Chevy Parts eBay
    Last Post: 11-30-2009, 08:40 PM
  5. Tail light and brake light recall
    By smiddy in forum Chevy Trailblazer Forum (GMC Envoy)
    Last Post: 09-19-2005, 04:39 PM
