Results 1 to 2 of 2
    Newbie chevysub is a glorious beacon of light
    Aug 2009
    Unhappy 98 suburban tapping / knocking
    I have a 1998 suburban and I just replaced the head gaskets it had alot of water and sludge in the pan and the intake valley, it started up ran great drove it on the freeway ran good oil pressure was normal 40 then all of a sudden the engine cuts off. pulled over turned it back on started to make a rattleing noise/ knock drove it and it went away but the idle is very low and the oil pressure is running about 20 then I got closer to home and it started to knock check gauges lite came pressure was very low as I was at a stop then I press the gas oil pressure goes close to 15. checked the oil and it was exteremly hot! and oil changed to a grayish color it had a little sparkle to it i think it has some metal particles, I ran 10-40 in it has about 120k on it. I looked at my rad and it has connections for a oil cooler lines and I looked at the oil filter where there should be lines and there wasn't any they had plugs on the oil filter mount, did they come this way?
    Update: I found a round shear in oil pan its from wrist pin bearing 8 and 7 where shot what should I do now?
    Jr. Engineer grimreapersshadow is a name known to all
    Apr 2009
    florida
    proably your best bet is gettin a new motor there only about 2300 bucks new it sounds like your about to toss a rod and thats not a cheep repair means a total tear down and check the entire block along with having a machine shop check your mains for squareness and such so you dont go down the road and toss all the bears and rods out in a mater of months http://www.summitracing.com/parts/NAL-12530283/ theres a link to summit with the L31-R motor that you need its a pretty simple swap if your gonna do it your self
Similar Threads
  1. loud tapping sound
    By madden0125 in forum General Chevy Tech Q&A
    Last Post: 07-08-2010, 11:43 PM
  2. 1998 suburban vortec knocking/ tapping
    By chevysub in forum Chevy Suburban Forum (GMC Yukon XL)
    Last Post: 12-20-2009, 04:45 PM
  3. Very strange tapping noise
    By zachh1020 in forum General Chevy Tech Q&A
    Last Post: 02-14-2009, 11:49 AM
  4. Tapping noise and strong fuel smell in exhaust
    By spirentc in forum Powertrain
    Last Post: 01-14-2008, 07:54 PM
  5. 01 enginge tapping
    By smatsu in forum Chevy Silverado Forum (GMC Sierra)
    Last Post: 01-21-2007, 05:01 PM
