Page 1 of 2 12 LastLast
Results 1 to 10 of 17
    Newbie alien4fish is a glorious beacon of light
    Aug 2009
    Default Newb with 95 suburban and rear a/c issues
    Hi Everyone, Im new to here(2nd) post,
    And Just bought my 1st chevy suburban, a 1995 1500 4x4 9 passenger Im pretty sure its the 5.7 Liter
    the truck runs great tons of power, bought it to tow a boat. when I got it the a/c compressor was shot so we had it replaced and recharged runs great but i have no a/c in the back, of the car for the kids just blows hot air and i cant figure out why. I did a search here but didnt get any good posts on cause and remedies.
    Diagrams would be great BTW or what is a common issue with these trucks? is this a common thing?
    Please give me some feed back Thanks kevin
    Legend Z71_guy is a splendid one to behold
    Feb 2009
    Minnesota
    welcome to the site, try posting in the tech section to get more answers
    2003 Z71 Silverado LS
    Access roll up cover
    Bed Rails
    Billet Grill insert
    Bed Rug
    CB with PA system
    Waiting to be installed
    Aug 2009
    in the tech section?? Ok thank you I will, thanks again,
    Kevin
    Master Mechanic tattooed4life is a splendid one to behold
    Apr 2008
    Stevensville MI
    Welcome to the site!
    1997 Chevy K3500
    4x4 X-Cab Dually
    454 Dual Exhaust
  5. #5
    Legend unplugged has a reputation beyond repute
    Sep 2006
    High Deserts of SoCal
    Welcome. You said you had the ac compressor replaced. Why didn't you have the rear air checked then or was it working fine after the compressor replacement?
    alien4fish: We burb owners gotta stick together. I recommend you post most tech q's here unless you think it is better placed in one of the tech forums.
    There is no way to happiness....happiness is the way.
    http://kx6ijq.blu.livefilestore.com/y1pcOFVNH4ix1hjyGUVyXK5LRfef7qSeWzlZDorpQhIEfkZ2ZA  _vXMYypuKMJFw671uF2ZPhjez_j-atRmcjM2zQKpQi1JSsB75/burb1.JPG
    High Desert SoCal
    93 K1500 burb (personal) 350 AT 3" Lift 250K+
    02 Honda Civic LX
    Looking for a 1990's Miata for an engine swap
  6. #6
    Aug 2009
    It's kind of long story found truck at dealer bought truck but for cheap wasn't readyfor salet yet the a/c had to work or I wouldn't buy it so they replaced the compressor and that was it they said they put 4 lbs in it but doenst the back blower have to be on when they charge it in the back? Is there a valve that opens?
  7. #7
    Newbie 1996z71 is a glorious beacon of light
    Aug 2009
    Default common spots
    first place to look is at the head of the compressor does it have two lines or four? if only two and the front unit works good you either have plugged line i.e. parts counter charge kit with stop leak in it or a bad rear evap if so i appoligize pulling that rear panel to acces it is a pain just did it in hte wifes 96 burboun if you have four lines at the head of the compressor the system probabley wasnt charged right because the rear unit must be switched on to take a charge if i remember correctly the two line set up takes three pound 134 the four line takes 4 pounds hope any of this helps be very gentle pulling the trim to access rear unit if you have to get to it
  8. #8
    Jr. Engineer Loggerhead Mike is a glorious beacon of light
    Aug 2009
    Franklin, NC
    did they say why the compressor was bad? bad coil, siezed up ect.
    when you access the rear lines and evap core feel the lines. hot/cold very cold or frosted over (that would indicate a restriction)
    may have a blend door problem
    GM TECH
    05 silverado shortbed
  9. #9
    Jr. Apprentice 7daughters is a glorious beacon of light
    Jul 2007
    Hillsboro, Or
    I have the same issue and it is the expansion valve in the rear unit. It is the valve that keeps the rear coil from freezing. When the coil gets so cold, it closes and prevents the freon from flowing. It is a $30 part, but requires a discharge of the system to replace it.
    1989 Pontiac Bonneville LE
    1995 Pontiac Bonneville SE
    1995 Chevrolet Suburban LS 1500 4x4
    2000 Pontiac Bonneville SSEi
  10. #10
    Aug 2009
    im not sure if its two or four line system i can take a pic and post it , for the rear a/c where can I find the expansion valve ? Like I said the front gets nice and coldf they did a good charging it so do i need to to turn on that fan switch at the top of the head liner and add more 134a?
Similar Threads
  1. 14 bolt rear brake issues..
    By hearsekid in forum General Chevy Tech Q&A
    Last Post: 03-07-2010, 11:04 PM
  2. Ultrasonic rear parking assist issues
    By chevymom in forum Chevy Tahoe Forum (GMC Yukon, Cadillac Escalade)
    Last Post: 01-19-2010, 01:08 PM
  3. 01 ASTRO rear hatch electrical issues
    By tonkatracker in forum Chevy Uplander Forum (Chevy Vans)
    Last Post: 01-27-2008, 01:33 PM
  4. Rear Differential issues- common ?
    By 03TrailBlazer in forum Chevy Trailblazer Forum (GMC Envoy)
    Last Post: 01-23-2006, 09:56 PM
