Results 1 to 7 of 7
    Legend
    ippielb is a name known to all
    Feb 2009
    Canada
    Default P0332 Knock Sensor
    Well, my truck got this code yesterday when i was driving into the city to get those tires. I stopped off at PartSource and got the codes read, this code came up twice. Is there anything i can do to try and fix this myself? I'm assuming since i got this code twice, one was for #1 and the other was for #2, so do both of my knock sensors need to be replaced? Am i correct that if i replace them, i need to take off my intake manifold and all that to access them? And that the reason that they're giving the code is because water got to them? Is this a hard fix? I've never done this one before.
    2002 Chevrolet Silverado 1500 z71
    6.5" BDS Suspension Lift Key'd to 9"
    5.5" Lift Springs with 4" Blocks
    35" Toyo Open Country Mud Terrain on 18" Ion Alloy 179's
    AirAid Cold Air Intake with K&N Dry Filter & AirAid PowerAid Throttle Body Spacer
    Pacesetter Long Tube Headers with Catalytic Converters Removed and True Dual Exhaust FlowPro Mufflers 4" Stainless Tips
    Bosch +4 Iridium Spark Plugs MSD Ignition Plug Wires
    Innovate LC-1 Wideband o2 Sensor x2
    BDS Dual Steering Stabilizers
    Electric Fan
    4.56 Gears
    EFI Live
    Sr. Apprentice Peckens is a glorious beacon of light
    Mar 2009
    Omaha, NE
    my haynes manual says you have to take the intake manifold off. mine just went out too and am going to replace
    Legend
    Feb 2009
    Canada
    There's actually two of them, one in the front toward the front of the vehicle and one in the back towards the back of the vehicle, mine costed $70 a piece. And i also suggest getting a new gasket mine costed $90.
    Electric Fan
    4.56 Gears
    EFI Live
    Legend Jimmiee has a reputation beyond repute
    Feb 2009
    Reno, Nevada
    Quote Originally Posted by ippielb View Post
    I wouldn't change them until I proved they were bad. Usually when a code sets especially multiple codes for several sensors it is not a bad sensor. The code sets when the sensors hear a knock. The PCM tries to fix the knock by retarding the timing. If the knock still persists then the hard code sets.
    With that being said here are some things to check:
    Noisy belts.
    Noisy tensioner
    Noisy lifter
    Exhaust leak
    Any unusual noise under hood.
    Boom box stereo
    Jim
    2004 SILVERADO 2500HD LS
    Pro Comp Leveling Kit
    Pro Comp Programmer
    Bilstein Shocks
    Linux Bed Liner
    Tinted Windows
    Other rides:
    1967 Landcruiser <350 Chevy>
    1970 Camaro
    1990 Geo Metro Convertible
    2007 FJ Cruiser
  5. #5
    Mar 2009
    Omaha, NE
    can anyone tell me the torque specs for the intake manifold?
  6. #6
    Jr. Apprentice Silverbullit is a glorious beacon of light
    Sep 2009
    Stafford, VA
    I just did mine this weekend it took about 4hr.....If i was you i would replace both of them since there a pain to get to........I would also make a horseshoe around them with RTV Glue this will help keep out the water a little on the gaskets wont hurt either.........GOOD LUCK!!!
  7. #7
    Sep 2009
    Stafford, VA
    Quote Originally Posted by Jimmiee View Post
    Noisy belts.
    Noisy tensioner
    Noisy lifter
    Exhaust leak
    Boom box stereo
    Hear is a good way to test the knock sensor before taking your engine apart...... Look for 2 wire's on the driver's side of your intake manifold each one goes to one of your knock sensor's they should be dark blue and light blue......Get a volt meter set it on A/C volts put one lead on your neg. battery post and the other to your knocksensor wire then Tap on your engine block with a wrench try to tap near the intake manifold you should get some kind of reading if not your sensor is bad........Hope This Helps!!!!
Similar Threads
  1. P0332 Knock Sensor 2 Circuit Low Bank 2....03' Suburban
    By SoundZman in forum Performance & Fuel
    Last Post: 06-08-2009, 07:44 PM
  2. Knock Sensor
    By avionics in forum General Chevy Tech Q&A
    Last Post: 06-06-2009, 01:29 PM
  3. Knock sensor
    By 91Chuck in forum Powertrain
    Last Post: 05-03-2009, 09:36 PM
  4. Where is knock sensor on 350 TBI?
    By Big6ft6 in forum Chevy Suburban Forum (GMC Yukon XL)
    Last Post: 10-22-2008, 11:19 AM
  5. knock sensor
    By gmcjohnny in forum Powertrain
    Last Post: 10-08-2008, 06:43 PM
