in a 99 tahoe , is the refrigerent 134 A ?
where would the low pressure "valve" be to recharge the system ?
in the engine compartment, I see 2 "valves"next to each other, one pointing up and one pointing toward the front of the truck.
is the one pointing up IS the low pressure ?
Thanks
Stefan - Beacon, NY
99 Chevrolet Suburban K1500 LS (My truck)
5.7L V8
CarPC, 1.6Ghz Intel Atom, 2GB DDR2 Ram, 250GB Harddrive, GPS, BT, WIFI, OBD2 Reader, 7" Lilliput Touch, 9" Headrest monitors, running Centrafuse.
348.000 miles
-Computer Consultant-
Have any computer problems or questions? Just send me a message and I'll see what I can do
ok thanks, I do not see any label inside the engine compartment which show the typre of refrigerent, so before I screw up, can somebody confirm it's 134a
sry, I didn't read properly your post , thanks again !!!!
Thanks
Stefan - Beacon, NY
5.7L V8
348.000 miles
i looked arround but didn't see anything, just the belt diagram. anyway, the ac shows 50 psi (in the overcharge zone) so I guess my problem is something else...![]()
Thanks
Stefan - Beacon, NY
5.7L V8
348.000 miles
yep ! full speed fan ac on, and recycling air on, I check the gage to see how low it was gonna be, suprise....50 psi....grrrr...
might also be too high pressure in the system, that has happened to me before.
Does the compressor turn on at all?
Thanks
Stefan - Beacon, NY
5.7L V8
348.000 miles
Bookmarks
