Well in another thread I stated that I spun a bearing pretty bad not worth fixing the block or crank so I decided to buy a block with pistons and crank and just slap on the heads etc... so what blocks year and models can I use on my suburban? thanks.
I'm no expert, but I'd think that the short block from '96 through '99 would work for you. In '96 GM went to the 350R engine, which should be what your Sub' has. I had a '99 3/4 ton with the same engine. In 2000 GM went to the 5.3 engine line. Hope this is what you needed.
2010 Z/71 Colorado C/C
Black 4X4 w/5.3L V8
2007 Winnebago Adventurer
w/8.1L Chevy & Allison 6spd.
Canyon Lake, Texas
the 350 you need is an L31, this would be the vortec 5.7
5.7 K&N & True Dual Exhaust
Hypertech III
05 17" Silverado rims
99 LS 1500 5.3 "THE MULE"
Reg Cab Long Box
285/75/16E Dunlop Rover M/T
___________________________
Jason
Thanks guys, just pickup a 1997 5.7 from a k3500 tommorow on goes the heads and etc..![]()
Bookmarks
