Results 1 to 3 of 3
    Jr. Apprentice OleBlue93 is a glorious beacon of light
    Jan 2009
    troy
    Default Differential Dilema
    hey i have a 93 chevy heavy half ton single cab long bed with 3 inch body lift and 33 inch Ground Hawgs and recently my rear end started making chattering noises and 3 days later the C clip in the GM IFS that holds the CV shaft in place in the front pumkin snapped out of place and the rear end is the spider gears are anialated well i plan on buying spider gears for the project and the c clip but my question is on a heavy half ton i dont know the gear ratio, the spline i know the rear end is a 14 bolt 9.5 and also i want some1s input if any1 has ever done this kind of project b4 in the front how hard is it
    BRIAN AVERITT
    Legend Jimmiee has a reputation beyond repute
    Feb 2009
    Reno, Nevada
    Look at your RPO codes in the glove box. You will see a G code like GT4 GT5 GU4 something like that. Post the code and we can help you identify the ratio.
    Also, if your spyder gears have broken apart usually there is damage done to the ring and pinion. Don't order any parts until you take the unit apart and inspect it.
    Jim
    2004 SILVERADO 2500HD LS
    Pro Comp Leveling Kit
    Pro Comp Programmer
    Bilstein Shocks
    Linux Bed Liner
    Tinted Windows
    Other rides:
    1967 Landcruiser <350 Chevy>
    1970 Camaro
    1990 Geo Metro Convertible
    2007 FJ Cruiser
    Jan 2009
    troy
    the ring and pinion is brand new less than 2000 miles on them i'll chack the code later and post it
    BRIAN AVERITT
Similar Threads
  1. Differential
    By Williys in forum Chevy Uplander Forum (Chevy Vans)
    Last Post: 08-08-2009, 10:31 PM
  2. injector dilema
    By minoa in forum General Chevy Tech Q&A
    Last Post: 07-27-2009, 08:24 AM
  3. What front differential in 06' 1/2 ton?
    By gocubs68 in forum Powertrain
    Last Post: 05-30-2009, 10:06 AM
  4. I want a new differential
    By CarpenterGuy in forum Powertrain
    Last Post: 08-24-2008, 08:15 PM
  5. My Dilema, F@#^!!!
    By vncj96 in forum Powertrain
    Last Post: 07-11-2008, 09:58 AM
