Results 1 to 6 of 6
    Newbie Dale Lake is a glorious beacon of light
    Aug 2009
    Default 5.3 l Suburban Loss of Power
    My 2003 5.3 Suburban is experiencing power loss. It only happens when driving for a prolonged period of time (1 hour) in hot weather. The check engine light comes on. Codes indicate O2 sensor and low voltage error. The fuel filter was change, but did not remedy the problem.
    Legend vncj96 is a name known to all
    Feb 2008
    Red Wing, Minnesota, United States
    1 Post(s)
    i would start checking all your O2 sensor wiring low voltage would indicate its not reading the sensor correctly or that there could be an exposed wire
    5.7 K&N & True Dual Exhaust
    Hypertech III
    05 17" Silverado rims
    99 LS 1500 5.3 "THE MULE"
    Reg Cab Long Box
    285/75/16E Dunlop Rover M/T
    ___________________________
    Jason
    Master Mechanic zubbiez is a glorious beacon of light
    Feb 2009
    Eagle Mountain Utah
    Do you also experience loss of power going up hills? if so looks like the fuel pump could be goiong.
    2000 Silverado Z71 Whipple Supercharger, JBA Headers,3" cat back Flowmaster Exhaust, Volant cai, Pioneer Preimer deck,Orion subwoofer,03 signal light mirrors,03 taililghts
    Aug 2009
    Yes, the power loss is when pulling up hills. I replaced the fuel pump about 8 months ago. However, it was not the problem I had at that time (it was a head gasket). I could have a bad pump. I'll check the wiring. How many O2 sensors are there?
  5. #5
    Feb 2008
    1 Post(s)
    not sure on the newer ones but my suburban has 4, you will have one in front and behind the cat, but you could have two cats thus making 4 sensors
    Hypertech III
    Reg Cab Long Box
    Jason
  6. #6
    Newbie Delco99 is a glorious beacon of light
    Mar 2009
    Default Is it overheating?
    It might be an O2 sensor, but kind of sounds like it is overheating to me. Correct me if I'm wrong, but I think these engines have a "conservative driving" mode that kicks in when it starts to overheat.
    1999 Silverado Reg. Cab Short Bed 5.3L 325cid
Similar Threads
  1. Loss Of Power
    By Pratt in forum Powertrain
    Last Post: 07-30-2010, 01:30 AM
  2. Loss in power . No CEL
    By Danow in forum General Chevy Tech Q&A
    Last Post: 07-12-2010, 12:07 PM
  3. Loss of Low end power
    By CBaker350 in forum General Chevy Tech Q&A
    Last Post: 05-24-2010, 06:14 PM
  4. loss in power
    By Silverado1500 in forum General Chevy Tech Q&A
    Last Post: 05-03-2010, 08:18 PM
  5. 94 suburban hesitation/loss of power
    By rickylee75160 in forum Powertrain
    Last Post: 05-16-2009, 11:18 PM
