    Default Location of ECM in '90 V2500 Suburban
    My good ol' truck started running rich so I read the codes and turns out it had a MAP sensor voltage low code. I replaced the MAP sensor and all was good for a while. Then the problem came back, same code. Seems to me that all that's left is the wires connecting the MAP sensor to the ECM or the ECM itself. Sensor still tests good with voltmeter. I would like to test from both ends of the wires and replace as necessary, but I don't know where the ECM is actually located. The wires are all bundled together and it's tough to tell where they go. If anyone knows it'd save me some looking around. thanks
    Legend unplugged's Avatar
    Sep 2006
    High Deserts of SoCal
    Default Where is the ECM on a GM Truck
    On mine it is behind the glove box. Remove the glovebox tray for access. Big ugly silver thingy.
    AutoZone has a pretty good component locator: http://www.autozone.com/autozone/rep...trol+Computer#
    High Desert SoCal
    02 Honda Civic LX
    Yep, it in dash on the right side. Rather than checking the wires you could watch the feedback on a scanner. If the feedback data changes <use a MightyVac> you know the wires have continuity.
    Jim
    2004 SILVERADO 2500HD LS
    Pro Comp Leveling Kit
    Pro Comp Programmer
    Bilstein Shocks
    Linux Bed Liner
    Tinted Windows
    Other rides:
    1967 Landcruiser <350 Chevy>
    1970 Camaro
    1990 Geo Metro Convertible
    2007 FJ Cruiser
    Thanks! The wire carrying the signal from the MAP sensor to the ECU was intermittent so I ran a new wire and we're good. The voltage low trouble code is not reappearing.
    Unfortunately, that was not the main problem. I'm going to start a new thread in the proper Chevy Suburban category since it appears to be a completely separate issue.
    http://www.gmtruckclub.com/forum/sho...806#post171806
  1. 1990 V2500 Suburban - running way too rich
    By Boldt in forum Chevy Suburban Forum (GMC Yukon XL)
    Last Post: 02-21-2011, 06:08 AM
  2. 89 Suburban ECU location?
    By bigbluesub in forum Chevy Suburban Forum (GMC Yukon XL)
    Last Post: 07-06-2010, 08:16 AM
  3. 1990 V2500 Suburban
    By The Burbs in forum Member Introductions
    Last Post: 09-24-2009, 09:49 PM
  4. 2004 Suburban Radiator Drain Location???
    By dgajr in forum GM Powertrain
    Last Post: 07-26-2009, 09:32 PM
  5. 2002 Suburban Jack Location
    By pelletman in forum General Chevy & GM Tech Questions
    Last Post: 01-11-2009, 01:23 AM
