Ok, when I bought the truck it was listed as a z71. But I dont have z71 stickers on the rear bed sides, I have 4x4 stickers back there. Is there a difference? If so what are they? Thanks for the help!
99 Silverado 1500 Z71
5.3L 4L60E Tranny
TransGo Shift Kit
2.5" Rough Country
Suspension Lift
33" BF Good A/T
Cherry Bomb Turbo
Cobra CB w/
Dual Fiberglass Antennas
01 Kawasaki KLR650
i am assuming you bought it used, you can look in the glove box and read the codes, or take the VIN to the dealership and they can tell, Z71 is stiffer shocks, skid plates and I believe thicker sway bars
5.7 K&N & True Dual Exhaust
Hypertech III
05 17" Silverado rims
99 LS 1500 5.3 "THE MULE"
Reg Cab Long Box
285/75/16E Dunlop Rover M/T
___________________________
Jason
If its got a 6 1/2' bed it also rides like a damn lumber wagon haha trust me i have one. either way Z71's ride alot rougher from the stiffer shocks. Deff worth it though if your off road alot.
It definately rides like a TRUCK which is what I want, I didn't buy no van wannabe. Its got skidplates and its got a stiffer suspension because my father-in-law has near same truck but no z71 or 4x4. When we hook our campers up his rearend sags even with a weight distributing hitch and when I hook up mine it doesn't even notice its there, no sag at all. Thanks for the help I will check the RPO's.
5.3L 4L60E Tranny
TransGo Shift Kit
2.5" Rough Country
Suspension Lift
33" BF Good A/T
Cherry Bomb Turbo
Cobra CB w/
01 Kawasaki KLR650
Well I have a 96 Z71. If you have one you will have a rear locking diff, the larger tires and like they say it will ride a bit harsher. there are a few more things but I can't remember at this time.
Thanks for the info!!
5.3L 4L60E Tranny
TransGo Shift Kit
2.5" Rough Country
Suspension Lift
33" BF Good A/T
Cherry Bomb Turbo
Cobra CB w/
01 Kawasaki KLR650
I hope you have a Z71... I would love to have one but right now just my 2wd V8 machine is killing in me gas
2000 GMC Sierra Ext. Cab 5.3L
4x4's are worse on gas, because it has to spin the front drive shaft along with the rear.
2002 Chevrolet Silverado 1500 z71
6.5" BDS Suspension Lift Key'd to 9"
5.5" Lift Springs with 4" Blocks
35" Toyo Open Country Mud Terrain on 18" Ion Alloy 179's
AirAid Cold Air Intake with K&N Dry Filter & AirAid PowerAid Throttle Body Spacer
Pacesetter Long Tube Headers with Catalytic Converters Removed and True Dual Exhaust FlowPro Mufflers 4" Stainless Tips
Bosch +4 Iridium Spark Plugs MSD Ignition Plug Wires
Innovate LC-1 Wideband o2 Sensor x2
BDS Dual Steering Stabilizers
Electric Fan
4.56 Gears
EFI Live
Bookmarks
