Results 1 to 2 of 2
    Jr. Mechanic nos351wcm is a glorious beacon of light
    Aug 2009
    Default What transmission fluid should i use?
    Im going to be flushing my tans fluid soon, and adding a trans intercooler from jegs rated at 16000 GVW. I plan on doing some towing. I checked AllData and the it calls for Dexron III fluid.
    Autozone has coastal dexron III, is this a good brand?
    Any recommendations on the fluid? the cooler?
    Thanks guys
    Cheers from NJ
    '00 1500 4x4 4.8l
    single glasspack
    daily driver/workhorse
    Sr. Apprentice Z07 is a glorious beacon of light
    Aug 2009
    Any that meets the Dex III spec is ok though I prefer national brands to house brands. Dexron is always backward compatible. So you could use Dex VI, for example, in a trans that calls for Dex III and you'd be fine. The newer are more expensive and so are the full synthetics. Since you are doing a flush stick with Dex III cheap stuff. Doing a flush with full synthetic would cost a bunch!
Similar Threads
  1. Transmission Fluid Waterfall
    By fullyloaded in forum Chevy Suburban Forum (GMC Yukon XL)
    Last Post: 03-07-2010, 07:57 AM
  2. complete transmission fluid change
    By mvoss2576 in forum Powertrain
    Last Post: 03-02-2010, 05:27 PM
  3. Transmission Fluid Change
    By makthenif in forum Chevy Suburban Forum (GMC Yukon XL)
    Last Post: 09-11-2009, 06:47 PM
  4. Replies: 3
    Last Post: 07-18-2009, 07:32 PM
  5. Transmission Fluid From Ams
    By RockHead in forum Powertrain
    Last Post: 03-07-2008, 10:52 AM
