GM Truck Club
Page 2 of 2 FirstFirst 12
Results 11 to 13 of 13
  1. #11
    Thanks for posting what fixed it.
  2. #12
    Default same issue kinda
    My 1991 suburban r2500 7.4L is running rich failed smog I have replaced the o2 due to a 44 code running lean. My smog guy said I'm running to rich and the old sensor was covered in blacl crud (another sign of running rich) I fixed 2 vac leaks, replaced pressure reg, injector o rings. Also I have no codes other then 12 after replacing o2. Any thoughts all pressure and fuel lines good new filter. Oh yeah it also chokes when I lightly press the gas pedal idle great high rpm great a little above idol runs cruddy.
  3. #13
    I actually had a few things wrong, not just the o2 sensor. Test the coolant temperature sensor, MAP sensor, and the wires connecting each back to the computer. I had a bad wire going to my MAP sensor, it must be pinched somewhere.
Similar Threads
  1. Running rich problem
    By ftms in forum Performance & Fuel
    Last: 06-07-2010, 02:38 PM
  2. 93' GMC Sierra 350 running really rich... HELP!!!
    By GearHead899 in forum Chevy Silverado Forum (GMC Sierra)
    Last: 05-15-2010, 11:18 PM
  3. 1990 V2500 Suburban
    By The Burbs in forum Member Introductions
    Last: 09-24-2009, 09:49 PM
  4. 1990 Suburban running poorly, need advice
    By gilland in forum General Chevy & GM Tech Questions
    Last: 02-23-2009, 11:32 AM
  5. Running rich
    By trivers in forum Chevy Suburban Forum (GMC Yukon XL)
    Last: 11-18-2007, 02:12 AM
