So, i'm doing my lift myself, and first thing to do in the front is to remove the torsion bars, i have the rear lift done, except for the add a leaf because all the spring stores are closed, and i want to get new leaf springs before i put it all back together. so i just put the blocks in, and put the u bolts on. and put it on railroad ties, and now i'm onto the front, i got my front tires off, jacked up on 20 tonne stands, and have blocks under everything to support it. And i swore i had a c clamp that would have worked, i checked it out when i tightened the torsion bars a couple turns, but now it's gone... So now i need to find a way to release the pressure without using the tools. Anyone got suggestions, other then go out and buy one?
[ame="http://www.youtube.com/watch?v=EprZDM24hyY&feature=fvw"]YouTube - Chevy Truck Lift Kit Installation : Chevy Truck: Removing Torsion Bars[/ame]
They did it without even using the unloader... How?
2002 Chevrolet Silverado 1500 z71
6.5" BDS Suspension Lift Key'd to 9"
5.5" Lift Springs with 4" Blocks
35" Toyo Open Country Mud Terrain on 18" Ion Alloy 179's
AirAid Cold Air Intake with K&N Dry Filter & AirAid PowerAid Throttle Body Spacer
Pacesetter Long Tube Headers with Catalytic Converters Removed and True Dual Exhaust FlowPro Mufflers 4" Stainless Tips
Bosch +4 Iridium Spark Plugs MSD Ignition Plug Wires
Innovate LC-1 Wideband o2 Sensor x2
BDS Dual Steering Stabilizers
Electric Fan
4.56 Gears
EFI Live
That truck was a Colorado. They must have more travel in the adjusting screw.
I think you can pull your lower ball joint and you won't need the unloader
pop the pad off of a c-clamp, and use the ball, and put it up their and clamp it down, remove bolt, and then slowly un-clamp it
I know guys have done this, and gotten away with it, but it's dangerous. And most of the c-clamps you buy today are very cheap chinese cast metal.
This thread has a link to a slightly less dangerous way.
http://www.gmtruckclub.com/forum/showthread.php?t=28024
if you do have a good quality one, it will work just fine, this is what the tool looks like, just a c-clamp with the pad removed, and a nut so you can use a wrench
http://store.fatbobsgarage.com/share...rce=googlebase
I think you can do the loan-a-tool deal at autozone and get the torsion tool.
1997 Chevy K3500
4x4 X-Cab Dually
454 Dual Exhaust
Well, hahaha, i'm such a redneck, me and a friend used a pipe wrench and a floor jack! It works too!
I'm now stuck on the lower ball joints on the lower A arm. Beat the crap out of my stock knuckles and its not budging....
Electric Fan
4.56 Gears
EFI Live
i would get a pickel fork after it so your not damaging the knuckle any more they make em in manual or ones that fit onto an air hammer so take your pick and have fun
Jim
2004 SILVERADO 2500HD LS
Pro Comp Leveling Kit
Pro Comp Programmer
Bilstein Shocks
Linux Bed Liner
Tinted Windows
Other rides:
1967 Landcruiser <350 Chevy>
1970 Camaro
1990 Geo Metro Convertible
2007 FJ Cruiser
An impact gun on a puller would speed things up, and possibly cause a puller failure. I went slow and easy, the old fashioned way. With a 3/4 drive ratchet and the gear puller. Still alive, all fingers, all arms, all eyes. But that's how I did it.
1998 K-2500 Suburban
454 w/ 4L80E
Suspension Maxx T-Bar Keys Gibson Cat Back K&N Intake
Mag-Hytec trans pan and diff cover Hypertech Programmer
MSD 6A, Blaster Coil & Wires Roadmaster Active Suspension
Hummer H2 wheels w/ BFG All Terrrain T/A KO
Bookmarks
