Results 1 to 6 of 6
    Jr. Mechanic ajaxajax2000 is a glorious beacon of light
    Nov 2007
    Default Check Engine light problem - please help
    Hi.
    My car is a '03 Z71 Burb and I got the following problem: When I turn the ignition ON everything looks ok. All lights come on and they all go out when I start the engine (except parking brake and seat belt warning lights). But when I turn the engine off and directly turn ignition back on the "Check Engine light" wont come on again. No matter how many times I try. Then again after waiting for some half hour, everything is back to normal.
    This has been noted as an issue by the Swedish car inspection agency (whatever that is called in English).
    Any ideas on what to do?
    Peter
    Sweden
    2003 Suburban Z71 4WD
    Nov 2007
    Some more info. If I take out the key, lock and unlock the doors with the remote, then the check engine lamp comes on as normal again.
    Is this as it should be?
    Peter
    Sweden
    Legend Jimmiee has a reputation beyond repute
    Feb 2009
    Reno, Nevada
    Here's the deal. You know the light works. If it never comes on then don't worry about it. If it comes on while the truck is running then you have a problem.
    Jim
    2004 SILVERADO 2500HD LS
    Pro Comp Leveling Kit
    Pro Comp Programmer
    Bilstein Shocks
    Linux Bed Liner
    Tinted Windows
    Other rides:
    1967 Landcruiser <350 Chevy>
    1970 Camaro
    1990 Geo Metro Convertible
    2007 FJ Cruiser
    Nov 2007
    Quote Originally Posted by Jimmiee View Post
    Right. Only I don't have a problem with this. It's "the Swedish Motor Vehicle Inspection Company" that keeps nagging on me!
    Peter
    Sweden
  5. #5
    Feb 2009
    Reno, Nevada
    I'm not familiar with their inspection policy but if if there are no trouble codes and the light bulb works, what more could they want?
    Jim
    Pro Comp Programmer
    Bilstein Shocks
    Linux Bed Liner
    Tinted Windows
    Other rides:
    1970 Camaro
    2007 FJ Cruiser
  6. #6
    Nov 2007
    They want it to work every time the key is turned, and then go out when the engine starts. But now I need to fiddle with the lock/unlock buttons to get the light to go on once the engine has been turned off after running. Sigh...
    Peter
    Sweden
Similar Threads
  1. check engine light
    By TJ99Sonoma in forum Member Introductions
    Last Post: 07-16-2010, 08:37 PM
  2. Check engine light on.
    By Andy7 in forum Performance & Fuel
    Last Post: 07-16-2010, 02:26 PM
  3. check engine light
    By eightbol21 in forum General Chevy Tech Q&A
    Last Post: 07-11-2010, 11:07 PM
  4. check engine light
    By Custom04Chevy in forum General Chevy Tech Q&A
    Last Post: 02-10-2009, 02:35 PM
  5. Check Engine Light
    By Nevada Born in forum Chevy Trailblazer Forum (GMC Envoy)
    Last Post: 12-27-2008, 02:18 AM
