I have a 07 Silverado 1500 crew cab... stock tires were (i believe) 275/50R17... i bought new rims and tires for this truck and now it vibrates alot, and sometimes violently when i brake. The new rims are 20" with 275/60R20 Cooper Zeon all terrain tires... Do I have too much tire under my truck for the stock braking system... does any one know how to fix this problem or whats causing it?
It's normal. Mine does the same thing. I put 20" wheels and tires on my 2007 Silverado and notice a lot of vibration. I just brake a little easier and a loittle sooner.![]()
2007 Chevy Silverado
5.3L Vortec V8
Black Crewcab
Chrome tow hooks
Chrome side view mirror caps
Stainless steel GM tie down hooks
Flowmaster turbo with Silverline tips (Dual Exhaust)
Back Wheel house liner
Chrome door handles
Chrome Chevy bowties front and back
I have the same prob. i just put some 22's on my 08 silverado and it vibrates like crazy when i brake
2008 chevy silverado z71
my truck shakes but i have stock rims/tires right now.
2006 Silverado Z71 - 97,000 - totaled, RIP
2006 Silverado Z71 - 70,000 (K&N 77 Series CAI, PowerAid TBS, Magnaflow dual rear exit, 33x12.50 Mickey Thompson MTZ, Tuff Country Torsion Keys, Tuff Country Add-A-Leafs)
I'll keep my money, guns, and freedom. You keep the Change.
your rotors are warped. next time you brake try and feel if the vibration is more in the steering wheel (the wheel will shimmy) or more noticible in the seat or floorboard. that will tell if you if your front rotors or rear are warped worse. usually your front
the new chevys are notorious for warping rotors. too big a tire and not enough metal in the rotors
and it is not normal. warped rotors will reduce your braking distance and wear your steering parts out faster
GM TECH
05 silverado shortbed
i've been meaning to take my rotors off and have them turned for some time now.
Yep, warped rotors (or possibly unevenly worn pads...less likely). Not something you want to ignore long term.
Another option is to upgrade to larger rotors and brakes, particularly up front, especially if running a larger diameter (heavier) rim. It can be a bit pricey (usually at least $300-$500 in parts for the fronts alone in most cases IIRC), but the improvement over stock and greater confidence in upgraded stopping ability to go along your upgraded rotating mass can be a great payoff as well. This probably applies more to those who are going to a 24"+ size rim.
-Slik
'01 Tahoe LT Air Ride, 23" Foose "Spanks"
Rotors warping? New chevys? What years and models? Is there a TSB out on this? Since you're a GM Tech I assume you are seeing this a lot in the shop? I'm just curious.
I have an 06 K1500 with stock 17" rims and 265/70-17, GoodYear RT/S with lots of tread on them.
The rotors look like they are fine for the size wheel/tire combination. I'm not sure if the front pads on my truck are original are not. Just bought the truck. They have plenty of meat left on them and the truck has 50K on it. The rotors look original. I can easily overcome the tires under braking and engage ABS and cause some lockup. So I have more brakes than tires at this point.
2006 Chevy Silverado, 5.3L, Z71, Extended Cab. Tow Mule.
2002 Chevy Corvette Z06, 5.7L, Slightly Modded. Tow Payload.
2005 Craftsman Riding Mower, 17hp, light mods.
thanks guys... ended up being the drums in the back, one was warped and the shoes were almost toast... then the front pads had to be replaced too, they were almost ready for a change as well... but thanks for the input... much appreciated...
Thanks for letting us know what the problem was. Helps us diagnose in the future, and makes searching much more productive.
Bookmarks
