Results 1 to 6 of 6
    Newbie russ115 is a glorious beacon of light
    Aug 2009
    Default Upgrading stock transmission cooler
    I have a 2004 Silverado 4x4 extended cap w/3:73 differental & towing package. I want to tow a 5000# travel trailer cross country in the spring, and wonder if I should replace the stock transmission cooler with a larger aftermarket stacked plate cooler & gauge. Has anyone changed coolers, and have suggestions on which one fit in w/o big install problems. Thanks
    Legend Z71_guy is a splendid one to behold
    Feb 2009
    Minnesota
    never seen anyone do it but i cant imagine that it would be difficult and a good idea for long hauls
    2003 Z71 Silverado LS
    Access roll up cover
    Bed Rails
    Billet Grill insert
    Bed Rug
    CB with PA system
    Waiting to be installed
    Jr. Apprentice truheel1 is a glorious beacon of light
    May 2009
    Charlotte NC
    Default extra cooler
    Why change? Just add the extra cooler and fluid as long as there is room it. 2 coolers........
    Legend Jimmiee has a reputation beyond repute
    Feb 2009
    Reno, Nevada
    Quote Originally Posted by russ115 View Post
    The stock one is probably OK but if you want a better one get a BW Long Tru-Cool stacked plate cooler.
    Also you have to be careful adding an extra cooler. I wouldn't recommend it if you do any driving in sub zero weather. Your fluid needs to warm us as fast as possible for maximum lubrication.
    Jim
    2004 SILVERADO 2500HD LS
    Pro Comp Leveling Kit
    Pro Comp Programmer
    Bilstein Shocks
    Linux Bed Liner
    Tinted Windows
    Other rides:
    1967 Landcruiser <350 Chevy>
    1970 Camaro
    1990 Geo Metro Convertible
    2007 FJ Cruiser
  5. #5
    Legend Crawdaddy has a reputation beyond repute
    Feb 2007
    1 Post(s)
    What do you recommend for those of us in the never-less-than-70-degrees part of the US? I am currently running my TH700R4 through a plate cooler only (no factory radiator in the loop) and I'm looking to add another plate cooler in line to make sure I have enough cooling while towing. Any thoughts?
    Christopher
    1991 Chevy Suburban 1/2 ton 2WD w/ chevy SBC 350-3/4 ton drivetrain upgrade w/4.10 gears 194K miles
    2005 Saturn ION-2 Stock 200K miles (In 6 years...ouch)
    1982 Bronco, 1993 Bronco, 1971 M35A2 Deuce and a Half
  6. #6
    Feb 2009
    Reno, Nevada
    Quote Originally Posted by Crawdaddy View Post
    If you eliminate the factory radiator cooler you NEED more cooling. The reason, and most people don't know this, is that aftermarket cooler ratings are based on the cooler running through the stock radiator. It doesn't really say that anywhere but in the fine print. So to answer your question two would be better cooling than one without the radiator cooler. And remember this is not good in cold climates. The newer transmission cooler systems now have a cold weather bypass that bypasses the coolers until the radiator warms up. Ford and Dodge are doing this now so I expect GM will follow suit.
    Jim
    Pro Comp Programmer
    Bilstein Shocks
    Linux Bed Liner
    Tinted Windows
    Other rides:
    1970 Camaro
    2007 FJ Cruiser
Similar Threads
  1. Adding a Transmission cooler
    By megapea in forum Powertrain
    Last Post: 04-09-2010, 06:25 PM
  2. Help !!! Transmission cooler lines
    By pedraza202 in forum General Chevy Tech Q&A
    Last Post: 12-02-2008, 03:20 AM
  3. Manual transmission cooler???
    By jbhofc in forum Chevy Silverado Forum (GMC Sierra)
    Last Post: 01-06-2008, 11:13 PM
  4. transmission oil cooler
    By DutchTBI in forum Chevy Tahoe Forum (GMC Yukon, Cadillac Escalade)
    Last Post: 03-03-2007, 10:48 AM
  5. Transmission cooler
    By coachw-n-themrs in forum Chevy Tahoe Forum (GMC Yukon, Cadillac Escalade)
    Last Post: 07-07-2006, 12:37 AM
