Results 1 to 9 of 9
Thread: 1996 chevy fuel pump
08-31-2009, 02:27 PM #1Newbie
- Join Date
- Feb 2009
- Location
- Oregon
- Posts
- 9
My friend has a 1996 chevy silverado 1/2 ton 350 4x4 he is on his 4th fuel pump. Dose any body know what causes these fuel pumps to fail ? About every 2 years he has a fuel pump fail. They are getting replace with the factory fuel pump and being installed by a chevy dealer. Is there any afftermarket fuel pumps out there that are better than stock ? Thanks for any answers you guys give.
08-31-2009, 03:13 PM #2
I have had good luck with Carter
2003 Z71 Silverado LS
Access roll up cover
Bed Rails
Billet Grill insert
Bed Rug
CB with PA system
Waiting to be installed
09-02-2009, 08:37 AM #3
I had issues with mine for a while, went through 3 or 4 pumps too. Have they replaced the sending unit too? The wiring seperated on mine where it exits the top of the tank. Heard several theories about these fuel pumps, don't drive it much below 1/4 tank (heats up the pump), only use ACDelco pumps(for some reason the wiring from the factory pump burns up off brand pumps), and there was a wiring issue with the pumps(the wires in the tank need to be replaced with the pump). Haven't had an issue with mine since replacing the sending unit.
'96 K1500, 5.7
6" RCD
35" Toyo M/T On 16" Black Raceline Raptors
4.56 Yukon Gears w/ TruTrac Rear
S&B CAI
Dual Flowmaster 40's
Camo Wet Okoles
Line-X Bedliner
De-Badged
NW BlackDiamond Edition
09-02-2009, 11:29 AM #4
This maybe stupid to you guys but have you changed the fuel filter a dirty filter causes the pump to work harder and burn up
www.myspace.com/teamimageracing
www.myspace.com/brotherspolish
2002 Silverado
5.3L
Corvette Servo
Spectre Air Intake
MSD 8.5mm Super Conductor Wires
AC Delco Iridium Plugs
Flowmaster 40 Series
Alpine Head Unit
Next Mods
2" Lowering Shackles
Loud Mouth Grill
:gasp:
09-02-2009, 10:10 PM #5Newbie
- Join Date
- Feb 2009
- Location
- Oregon
- Posts
- 9
Yes fuel fillters have been change regularly. He got a fuel pump today I guess I will be putting it in sat.
Is it a very hard job to do never done a intank fuel pump before.
09-03-2009, 07:31 AM #6Newbie
- Join Date
- Aug 2009
- Posts
- 7
carter fuel pump...99 c1500
I just purchased a carter fuel pump unit/complete w/sender... The wire plug end needed to be changed but the colors on the truck harness do not match the ones from carters replacement plug. The truck harness has purple/w white stripe, green, and 2 black wires while the replacement plug has a purple,green,black and orange/w black stripe. Easy enough if the purple wires and green wire are a match but does it mater where the 2 blacks from the truck harness go.... to the orange /w black stripe and black on the plug end??? are they both ground wires? I am assuming that both the blacks from the truck harness are grounds????
09-06-2009, 12:09 AM #7
yeah one solid black is ground that run out and to the frame from the pump and i believe the other is from the relay up under the hood
09-06-2009, 04:27 PM #8Newbie
- Join Date
- Feb 2009
- Location
- Oregon
- Posts
- 9
Well got it done it was not to hard of a job only took about 3 hours.
09-07-2009, 07:09 AM #9Newbie
- Join Date
- Aug 2009
- Posts
- 7
carter fuel pump wires
I looked better at the black.. ground... wires and found that they were different gage wires...make sure the wires you connect for the ground are the proper gage. I bet if you hook up the ground wires wrong you could cause a problem ...wires overheating due to excessive current on too small a wire
Similar Threads
1999 chevy silverado fuel pump not working
By dugy40 in forum Performance & FuelReplies: 6Last Post: 01-31-2012, 09:53 PM -
(1996 Chevrolet Blazer Question): HOW TO CHANGE A FUEL PUMP
By Steve in forum Chevy Blazer Forum (GMC Jimmy)Replies: 3Last Post: 07-09-2011, 11:05 PM -
Fuel Pump Issues w/Chevy 3500 7.4L
By rowekmr in forum Performance & FuelReplies: 1Last Post: 07-20-2010, 10:43 PM -
00 chevy bad fuel pump
By edean37 in forum Chevy Silverado Forum (GMC Sierra)Replies: 4Last Post: 10-28-2009, 12:03 PM -
1984 Chevy C20 Fuel Pump
By 84ChevyC20 in forum Chevy C/K Truck ForumReplies: 2Last Post: 05-01-2009, 05:00 PM
Bookmarks
