Results 11 to 15 of 15
    Quote Originally Posted by Smokey View Post
    when I open the door to trigger the interior light, my pull jump to 2.6 amps! Everything I've seen says a normal pull for interior lights in around .98 Have I got some crazy interior lights or something?
    Going to depend upon how many lights come on when you open the door. Other things "wake up" as well.
    One 10 watt lamp at battery voltage is going to draw 0.8 amps.
    Pull the fuse for the interior lights and see if there is still a draw when the door is opened.
    Ok, I have a question. I have a 2004 Silverado 2500HD and I've had the same type of slow battery drain. I just hooked up my meter and with nothing else on, I have a .54 amp drain going on. I'm going to start pulling fuses and see what I can find. On top of that, when I open the door to trigger the interior light, my pull jump to 2.6 amps! Everything I've seen says a normal pull for interior lights in around .98 Have I got some crazy interior lights or something?
    your .5 AMP draw is too high. should be below .25AMP or lower after about 15min.
    with a 12volt system each light bulb will draw a good amount of amps. a 12 WATT bulb will draw 1 AMP. when you open the door the interior lamps will draw a few amps.
    went a chevy dealer...parts man claimed he had never heard of a gauge cluster module...where is it located....oh, by the way,they wanted to do a leak test for a $100.00
    the gauge cluster has an electronic module on it. the dealership would change the dash cluster. now there is no diagrams available with this . GM top secret !
    thanks...the guy who redid my cluster had not heard of it
  1. '99 Silverado Battery drain after setting several days
    By oldmangoodwrench in forum Member Introductions
    Last Post: 01-05-2010, 06:46 PM
  2. 1998 Suburban battery drain
    By nmtrout in forum Audio, Video & Gadget Tech
    Last Post: 08-11-2009, 09:03 AM
  3. Battery Drain/Relay problem
    By blaik in forum Chevy Suburban Forum (GMC Yukon XL)
    Last Post: 05-28-2009, 10:09 PM
  4. battery power drain on older CHEVs
    By theburban in forum Audio, Video & Gadget Tech
    Last Post: 02-03-2009, 10:59 PM
  5. Battery drain overnight? [Expired Topic]
    By technojunkie in forum Chevy Suburban Forum (GMC Yukon XL)
    Last Post: 01-19-2007, 02:37 PM
