Results 1 to 10 of 15
    Default Battery drain issue
    Hello All,
    So has anyone had any luck in figuring out what is causing the battery drain issue son our trucks?
    I've googled the issue until my fingers have bleed and still have not found an answer. In the mean time I will continue to troubleshoot and take readings.
    2007 Silverado 1500 LTZ Extended cab 4x4 5.8 ft bed
    Exterior: Black
    Interior: Light Titanium/Dark Titanium Accents
    Features: Auto-Dimming Inside Rearview Mirror, Power Door Locks, Power Sunroof w/Express-Open, Power Windows w/Driver Express-Down, Power folding side view mirrors w/blinker arrow, Radio: AM/FM Stereo w/MP3 Compatible 6 Disc CD Player, XM Satellite Radio, On-Star
    Quote Originally Posted by Coneklr View Post
    Hello All,
    If you have a battery drain it's easy to find with a DVOM meter. First step is to verify the drain. You should have no more than 300 Miliamp draw with the system powered down. Remove the negative battery cable from the battery and attach a jumper from the negative battery post to the positive lead of the DVOM meter set to Amps. Next attach a jumper from the negative meter lead to the battery cable. <Note that most DVOM meters have a built in 10 Amp Fuse. If you have a big drain you will blow the meter fuse so be careful and if you suspect a large draw an Amp Clamp is a better choice because it won't blow the meter fuse.
    Now with the amp meter in place do not turn the key on. Remember the dome light will illuminate and draw amperage if you open the door. Another suspect is the glove box light. Very common battery draw that fools a lot of techs.<G>
    Next start removing fuses one at a time until you find the circuit with the parasitic draw. Once you isolate the circuit it's just a matter of checking the accessories on that circuit.
    Jim
    2004 SILVERADO 2500HD LS
    Pro Comp Leveling Kit
    Pro Comp Programmer
    Bilstein Shocks
    Linux Bed Liner
    Tinted Windows
    Other rides:
    1967 Landcruiser <350 Chevy>
    1970 Camaro
    1990 Geo Metro Convertible
    2007 FJ Cruiser
    Quote Originally Posted by Jimmiee View Post
    Good info. THx
    Exterior: Black
    Do you have any type alarm system, tracking system, or anti theft system?
    Did you pull the relays too? If not pull all the relays out. Like Tim said, suspect ANY and ALL aftermarket accessories, brake controllers, stereos, alarms, CBs, anything added that's not a factory accessory including a trailer plug.
    Jim
    Pro Comp Programmer
    Bilstein Shocks
    Linux Bed Liner
    Tinted Windows
    Other rides:
    1970 Camaro
    2007 FJ Cruiser
    One thing I found on my old truck that was draining the battery, was the On-Star even though it wasn't activated. I pulled that fuse and then it was all good, just a thought.
    with your truck running check charge voltage at battery with meter set to read AC voltage, if you read any, would indicate bad diode in alternator. This would cause a drain.
    Or since you are seeing a drain, disconnect the alternator ......... and see if your draw goes away.
    danv
    i just got back from getting a drainage issue fixed at a dealership,as it turns out,it was the gauge cluster module that was causing the drain,it was a spendy fix,but at least i wont have buy batterys for for a hundred a clip anymore
  1. '99 Silverado Battery drain after setting several days
    By oldmangoodwrench in forum Member Introductions
    Last Post: 01-05-2010, 06:46 PM
  2. 1998 Suburban battery drain
    By nmtrout in forum Audio, Video & Gadget Tech
    Last Post: 08-11-2009, 09:03 AM
  3. Battery Drain/Relay problem
    By blaik in forum Chevy Suburban Forum (GMC Yukon XL)
    Last Post: 05-28-2009, 10:09 PM
  4. battery power drain on older CHEVs
    By theburban in forum Audio, Video & Gadget Tech
    Last Post: 02-03-2009, 10:59 PM
  5. Battery drain overnight? [Expired Topic]
    By technojunkie in forum Chevy Suburban Forum (GMC Yukon XL)
    Last Post: 01-19-2007, 02:37 PM
