I think I need to replace the starter on the the truck, where is it located ? how difficult is it to change it ?
its on the engine right buy the tranny bell housing
is access and removal difficult ?
idk, i haven't removed mine, and haven't been down their for a while looking at that
Fairly simple to change and it is very easy to get to. One of the simpler things to change out.
1997 Chevy K3500
4x4 X-Cab Dually
454 Dual Exhaust
Jim
2004 SILVERADO 2500HD LS
Pro Comp Leveling Kit
Pro Comp Programmer
Bilstein Shocks
Linux Bed Liner
Tinted Windows
Other rides:
1967 Landcruiser <350 Chevy>
1970 Camaro
1990 Geo Metro Convertible
2007 FJ Cruiser
you're up early !!!!'its acting up on me, since last tuesday, when i turn the key on, all the lights on the dash come on, but then nothing, and if i keep the key in the crank position for 2, 3 seconds it will (most of the time) turn in slow motion and the truck will start. the battery is brand new and while the truck is running shows 14v. (but when the ignition is on before starting the engine it shows only 10; 11 v....)
I get up at 5AM cause I'm an old fart. <G>
Before changing the starter verify the battery condition with a volt meter. Turn the headlights on for 20 seconds and then turn them off and read the voltage. Use a good volt meter not the one in the dash. A good battery should read 12.6 volts. A battery with 75% charge will read 12.4. If the voltage is less than 12.4 then don't change the starter just yet. Remember an engine can start with a battery that is almost dead. If the battery is new it may have bad cable connections. If the battery recovers to 12.4 after the headlamp test then the starter is probably bad. If the battery voltage of a good battery drops more than 3 volts while cranking <before it starts> then the starter is drawing too many amps and is probably bad.
Jim
Pro Comp Programmer
Bilstein Shocks
Linux Bed Liner
Tinted Windows
Other rides:
1970 Camaro
2007 FJ Cruiser
Bookmarks
