    Angry Lost 3-4 gear?!!
    Well after getting my suburban running it will shift from 1-2 and it will just rev when it hits third gear no codes could it be a 2-3 solenoid or I am I looking at a rebuild? How can I put the tranny in limp mode to see if 3rd gear grabs? thanks 1997 suburban 5.7 4x4
    forgot to mention it has very strong reverse works good.
    You can pull the transmission fuse. That will cut the voltage to the trans which should default to 3rd gear. A check of trouble codes will also help pinpoint the problem. A bad solenoid will not cause a neutral condition. Hows the fluid condition?
    Jim
    2004 SILVERADO 2500HD LS
    Pro Comp Leveling Kit
    Pro Comp Programmer
    Bilstein Shocks
    Linux Bed Liner
    Tinted Windows
    Other rides:
    1967 Landcruiser <350 Chevy>
    1970 Camaro
    1990 Geo Metro Convertible
    2007 FJ Cruiser
    Fluid doesn't look too healthy what is the fuse called that I should pull? Thanks
    It will say transmission or trans. You can also disconnect the connector to the trans but that's a lot of work.
    Jim
    Pro Comp Programmer
    Bilstein Shocks
    Linux Bed Liner
    Tinted Windows
    Other rides:
    1970 Camaro
    2007 FJ Cruiser
    I looked at fuses the one in the engine and the driver side panel and I didn't see a fuse called trans is there another block of fuses somewhere?
    sorry found the fuse its the PRND321 Fuse will I pulled it and dropped it to D and it grabbed good like it was in first so I dropped the gear into first and it moved up slowly like it was in third so whats going on whats my next move? thanks.
    If you don't have 3rd gear with the fuse removed the 3-4 clutches are probably burned up. Pull the pan to verify.
    Jim
    Pro Comp Programmer
    Bilstein Shocks
    Linux Bed Liner
    Tinted Windows
    Other rides:
    1970 Camaro
    2007 FJ Cruiser
  1. HELP I am Lost!!!!
    By bublitz3 in forum Chevy Suburban Forum (GMC Yukon XL)
    Last Post: 02-23-2010, 09:55 PM
  2. lost fwd
    By 1gun in forum GM Powertrain
    Last Post: 02-06-2010, 08:49 PM
  3. I lost my job.
    By plumber_rob in forum The Coffee Shop ~ Chit Chat
    Last Post: 08-16-2009, 11:35 PM
  4. lost 1st & 2nd gear on collum shifter linkage on my 98' tahoe
    By mmtahoe in forum General Chevy & GM Tech Questions
    Last Post: 07-26-2009, 08:40 PM
  5. lost performance
    By heavy chevy in forum Performance & Fuel
    Last Post: 02-26-2009, 10:24 PM
