A friend has a 78 chevy Blazer 4x4 350 engine and 350 turbo tranmission. Here is the problem:
Driving down the road and acts like it is shifting into N. I let off the throttle and then step back on it and it works fine.
Another problem sometiems it will just down shift inot second from drive.
THanks, M
1994 Suburban 5.7
Automatic 4x4
14 mpg
Check the fluid level first. Then make sure the kick down cable is adjusted properly. If the cable is adjusted too tight it will cause this kind of problem. If you're not sure disconnect it as a test.
Next pull the line off the modulator with the engine off and check it for leakage. If it has oil in the vacuum line change the modulator. If it's dry check the vacuum at idle. You should have at least 18" at idle.
Jim
2004 SILVERADO 2500HD LS
Pro Comp Leveling Kit
Pro Comp Programmer
Bilstein Shocks
Linux Bed Liner
Tinted Windows
Other rides:
1967 Landcruiser <350 Chevy>
1970 Camaro
1990 Geo Metro Convertible
2007 FJ Cruiser
Bookmarks
