    Default Trans leak 99 2 door Tahoe
    Went to drive the hoe to work today. Pulled it out of the garage to dust her off, and as I was walking into the garage to get the duster, I find red fluid on the gargae floor. Squeezing my head between the frame and concrete floor, I see tranny fluid covering the knuckle that connects the rear of the tranny to the drive line.
    I guess its safe to say the rear seal needs replacing ? No leaks anywere else but the knuckle.
    Quote Originally Posted by Surf911S View Post
    Take a close look to see if the seal is leaking or if the fluid is coming out of the center of the yoke. If there is a hole in the center of the yoke and fluid coming out there then you need to replace the o ring which requires removing the tail shaft housing. If there is no hole there then the rear seal is leaking.
    Jim
    2004 SILVERADO 2500HD LS
    Pro Comp Leveling Kit
    Pro Comp Programmer
    Bilstein Shocks
    Linux Bed Liner
    Tinted Windows
    Other rides:
    1967 Landcruiser <350 Chevy>
    1970 Camaro
    1990 Geo Metro Convertible
    2007 FJ Cruiser
  1. Odd Sierra NV3500 Trans leak. 5 speed
    By defektes in forum GM Powertrain
    Last Post: 03-13-2014, 12:12 AM
  2. 2008 Acadia water Leak by door?
    By Rumpamuro in forum Chevy Traverse Forum (GMC Acadia, Buick Enclave)
    Last Post: 09-26-2011, 08:43 PM
  3. 1999 Tahoe trans case leak
    By tmooy in forum GM Powertrain
    Last Post: 06-29-2008, 10:42 AM
  4. 3rd door window leak
    By ras in forum Chevy Silverado Forum (GMC Sierra)
    Last Post: 08-06-2007, 11:43 AM
  5. Water leak on '07 Tahoe
    By wswinford in forum Chevy Tahoe Forum (GMC Yukon, Cadillac Escalade)
    Last Post: 03-06-2007, 11:48 AM
