First off, great forum, everyone. I am getting ready to put rear brake pads on my '03 Silverado Ext. cab Z71. The Chilton manual says to open the bleed valves when compressing the pistons on ABS models. Is this in addition to removing fluid from the resevoir? I'd rather not fool with the bleed valves if possible. How do ya'll do pad changes on ABS models? Any help is appreciated.
hi you have to open the bleeder so you dont push the fiuld back up to the master cylinder. you could do danage.you dont have to remove any fiuld. hope this helps
http://s1191.photobucket.com/albums/z477/noell1947/pbr%20time/
2004 Chevy Colorado 2wd/4l60e/3.5 Inline 5
6-PIAA 520 series yellow ion spot lights 85 watts each
PIAA quattro fog lights w/extreme white/yellow ion bulbs
Anzo projector headlights/LED turn signals
LED underbodys 7-color/LED interior lighting
JET stage 2 performance chip/Magnaflow exhaust S/S
Recon Big Rig Lights/LED tail lights/3rd brake light
Putco LED bed lights/BEDRUG
Goodmark 2" rise Cowl hood/K&N fipk intake
98-04' Blazer overhead console & floor console
40/60/40 seat modified to 40/console/40
33" Cooper Discovery A/T
16" Pro Comp extreme alloy wheels
Jim
2004 SILVERADO 2500HD LS
Pro Comp Leveling Kit
Pro Comp Programmer
Bilstein Shocks
Linux Bed Liner
Tinted Windows
Other rides:
1967 Landcruiser <350 Chevy>
1970 Camaro
1990 Geo Metro Convertible
2007 FJ Cruiser
they say not too because your pushing contaminated fluid back into the system. barly crack the valve on the caliper so when you push the pistin in fluid will seap out. may have to do a quick bleed but as long as its barely cracked you shouldnt get air in the system
GM TECH
05 silverado shortbed
Thanks for the help
Bookmarks
