Results 1 to 10 of 10
    Jr. Apprentice rwag1945 is a glorious beacon of light
    Sep 2009
    Unhappy 2004 Chevy tahoe Wiring Problem
    I have a 2004 Chevy Tahoe, which apparently has a wiring harness problem.
    I have two trailers, both with new wiring harnesses and light assemblies.
    ALL Tahoe lights work fine without a trailer connected.
    Trailers have good grounds.
    The Tahoe plug at the back tests “good” on all connections UNTIL the trailer is plugged in. Then the lights go crazy.
    The Tahoe ground then tests “hot”
    Tahoe lights: none on trailer
    Brakes lights: none on trailer
    Left Directional: good on trailer and Tahoe
    Right Directional: none on trailer; Tahoe works, but both tail lights come on
    Brake & left directional: Trailer has left directional; no brakes; Tahoe ok
    Brake & right directional: Trailer has LEFT directional; no brakes; Tahoe ok
    Lights & left directional: Trailer has left directional; no tail lights; Tahoe ok
    Lights & right directional: Trailer has no lights; Tahoe has tail lights, but right directional stays on and does not blink
    Both trailers have the same performance.
    The Tahoe wiring has never been damaged or under water, and has worked fine for five years.
    Can it be the right tail light module on the Tahoe? Wiring harness?
    Legend
    canislupis69 is a glorious beacon of light
    Dec 2008
    Afghanistan...for now
    1 Post(s)
    1 Thread(s)
    Welcome to the site...you will get more responses if you post under the Tech section.
    Bobby - North Carolina
    2008 4x4 5.3L V8
    6" Suspension Lift and 1.5" Body Lift
    20x9 Ballistic Jesters w/35" Toyo Open Country MT's
    4:56 Yukon Gears
    Hypertech Speedometer Calibrator
    Baja style bed mount spare tire carrier
    Flowmaster 40 series dual exhaust
    Recon Smoked LED tails and 3rd brake lights
    N-Fab Nerf Steps
    K&N CAI
    No Fear Pedals
    Tint, Line-X bedliner, Window visors, Rear wheel well liners
    Painted front grill, bow ties and door badges, de-"lettered" tailgate
    Powder coated front and rear bumpers
    Master Mechanic tattooed4life is a splendid one to behold
    Apr 2008
    Stevensville MI
    Quote Originally Posted by rwag1945 View Post
    Is it a 4-way or a 7-way plug on the back of your tahoe? If it's a 4-way plug those can heat up and over time they start to melt the rubber and the wires short themselves. The only fix for this is to replace the whole harness. (simple plug in play repair) If its a 7-way plug, take the housing apart and inspect all the connections for corrosion or loose wires. They have a tendancy to collect moisture. Remove them and clean up with sandpaper or a file and some electronic parts cleaner. When I did mine I also put a little dielectric grease on each connection to ward off the moisture. Good luck, hopes that helps. and Welcome to the site!
    1997 Chevy K3500
    4x4 X-Cab Dually
    454 Dual Exhaust
    Legend
    adampaul1964 has a reputation beyond repute
    Feb 2009
    Greencastle, Pennsylvania, United States
    Adam
    2005 Z71 Silverado Crew Cab
    previous:
    '97 Chevy Suburban LT
    '94 GMC Sierra SLE
  5. #5
    Legend Jimmiee has a reputation beyond repute
    Feb 2009
    Reno, Nevada
    This is a very common problem. Electricity is lazy and seeks the easiest path to ground. If you find voltage on the ground and it tests "hot" then you have found the short. High resistance in the plug is the most likely cause. Take the trailer plug apart and clean the wires. If you want a better fix for this problem tin the tips of the wires with solder before you re-assemble the plug.
    Jim
    2004 SILVERADO 2500HD LS
    Pro Comp Leveling Kit
    Pro Comp Programmer
    Bilstein Shocks
    Linux Bed Liner
    Tinted Windows
    Other rides:
    1967 Landcruiser <350 Chevy>
    1970 Camaro
    1990 Geo Metro Convertible
    2007 FJ Cruiser
  6. #6
    Sr. Engineer seffieldvillage@aol.com is a glorious beacon of light
    Feb 2009
    ohio
    goes the trailers have led lights. that could be it. they dont pull the same voltage.
    http://s1191.photobucket.com/albums/z477/noell1947/pbr%20time/
    2004 Chevy Colorado 2wd/4l60e/3.5 Inline 5
    6-PIAA 520 series yellow ion spot lights 85 watts each
    PIAA quattro fog lights w/extreme white/yellow ion bulbs
    Anzo projector headlights/LED turn signals
    LED underbodys 7-color/LED interior lighting
    JET stage 2 performance chip/Magnaflow exhaust S/S
    Recon Big Rig Lights/LED tail lights/3rd brake light
    Putco LED bed lights/BEDRUG
    Goodmark 2" rise Cowl hood/K&N fipk intake
    98-04' Blazer overhead console & floor console
    40/60/40 seat modified to 40/console/40
    33" Cooper Discovery A/T
    16" Pro Comp extreme alloy wheels
  7. #7
    Sep 2009
    Jimmiee....
    Thanks for the info on the Tahoe wiring.
    Ron
  8. #8
    Sr. Engineer dsrtne1 is a glorious beacon of light
    Feb 2009
    Southern CA
    Michael, 17, CA
    2005 Silverado - See my garage for my mod list
  9. #9
    Legend retired2001 is a glorious beacon of light
    Nov 2006
    Canyon Lake, Texas
    Welcome to the site, Ron!
    2010 Z/71 Colorado C/C
    Black 4X4 w/5.3L V8
    2007 Winnebago Adventurer
    w/8.1L Chevy & Allison 6spd.
    Canyon Lake, Texas
  10. #10
    Master Mechanic GMPartsClub is a glorious beacon of light
    Sep 2008
    Dallas, Texas
    Hello Ron,welcome to the site!
    Please visit www.gmpartsclub.com for all your Chevy Parts needs. These are factory OEM GM Parts with full GM warranty (unless otherwise stated).
    ** Lost your Keyless Entry Remote? Contact us and get a factory replacement for less than you think.
    Or give us a call us 877-347-6220 (New Expanded Hours)
    Monday to Friday - 7 AM to 6 PM Central
    Saturday - 8 AM to 2 PM Central
Similar Threads
  1. 2004 Tahoe AMP problem
    By snarf412 in forum Audio / Video Electrical
    Last Post: 06-13-2010, 11:58 PM
  2. 2004 Tahoe Trailer Tow Wiring
    By rwag1945 in forum Chevy Tahoe Forum (GMC Yukon, Cadillac Escalade)
    Last Post: 09-14-2009, 02:21 PM
  3. 2004 Tahoe Tow Package Wiring
    By rwag1945 in forum Audio / Video Electrical
    Last Post: 09-06-2009, 08:27 PM
  4. 2004 Tahoe wiring problem
    Last Post: 09-06-2009, 09:29 AM
  5. 2004 Chevy Tahoe Wiring Problem
    By rwag1945 in forum General Chevy Tech Q&A
    Last Post: 09-05-2009, 12:29 PM
