Results 1 to 3 of 3
    Jr. Apprentice rwag1945 is a glorious beacon of light
    Sep 2009
    Unhappy 2004 Tahoe wiring problem
    I have a 2004 Chevy Tahoe, which apparently has a wiring harness problem.
    I have two trailers, both with new wiring harnesses and light assemblies.
    ALL Tahoe lights work fine without a trailer connected.
    Trailers have good grounds.
    The Tahoe plug at the back tests “good” on all connections UNTIL the trailer is plugged in. Then the lights go crazy.
    The Tahoe ground then tests “hot”
    Tahoe lights: none on trailer
    Brakes lights: none on trailer
    Left Directional: good on trailer and Tahoe
    Right Directional: none on trailer; Tahoe works, but both tail lights come on
    Brake & left directional: Trailer has left directional; no brakes; Tahoe ok
    Brake & right directional: Trailer has LEFT directional; no brakes; Tahoe ok
    Lights & left directional: Trailer has left directional; no tail lights; Tahoe ok
    Lights & right directional: Trailer has no lights; Tahoe has tail lights, but right directional stays on and does not blink
    Both trailers have the same performance.
    The Tahoe wiring has never been damaged or under water, and has worked fine for five years.
    Can it be the right tail light module on the Tahoe? Wiring harness?
    Legend unplugged has a reputation beyond repute
    Sep 2006
    High Deserts of SoCal
    I don't think there is a "module" for the brake lights. If you mean the tail light assembly, then yes there might be a short that could cause a problem.
    Check out the faq at etrailer.com http://www.etrailer.com/faq-wiring.aspx
    Dig a little deeper at the site and they have vehicle specific info. Phone support from these guys is fantastic too. Of course it's a good idea if you buy your trailer stuff from them too.
    There is no way to happiness....happiness is the way.
    http://kx6ijq.blu.livefilestore.com/y1pcOFVNH4ix1hjyGUVyXK5LRfef7qSeWzlZDorpQhIEfkZ2ZA  _vXMYypuKMJFw671uF2ZPhjez_j-atRmcjM2zQKpQi1JSsB75/burb1.JPG
    High Desert SoCal
    93 K1500 burb (personal) 350 AT 3" Lift 250K+
    02 Honda Civic LX
    Looking for a 1990's Miata for an engine swap
    Sep 2009
    Quote Originally Posted by unplugged View Post
    i don't think there is a "module" for the brake lights. If you mean the tail light assembly, then yes there might be a short that could cause a problem.
    dig a little deeper at the site and they have vehicle specific info. Phone support from these guys is fantastic too. Of course it's a good idea if you buy your trailer stuff from them too.
    thanks..e trailer is great
Similar Threads
  1. 2004 Tahoe AMP problem
    By snarf412 in forum Audio / Video Electrical
    Last Post: 06-13-2010, 11:58 PM
  2. 2004 Chevy tahoe Wiring Problem
    By rwag1945 in forum Member Introductions
    Last Post: 09-21-2009, 06:32 PM
  3. 2004 Tahoe Trailer Tow Wiring
    By rwag1945 in forum Chevy Tahoe Forum (GMC Yukon, Cadillac Escalade)
    Last Post: 09-14-2009, 02:21 PM
  4. 2004 Tahoe Tow Package Wiring
    By rwag1945 in forum Audio / Video Electrical
    Last Post: 09-06-2009, 08:27 PM
  5. 2004 Chevy Tahoe Wiring Problem
    By rwag1945 in forum General Chevy Tech Q&A
    Last Post: 09-05-2009, 12:29 PM
